OEM Bi Xenon HID and Halogen
How do your X5 Bi-Xenons work.
HID for dip and main beam. Inner halogens for flashing only
0
No votes
HID for dip and main beam, inner halogens assist on main beam giving a very bright centre beam
2
100%
HID for everything even flashing.
0
No votes
Total votes: 2
jaynana
Re: OEM Bi Xenon HID and Halogen
Post by jaynana » Sat Feb 09, 2013 7:31 pm
psychosis
Post by psychosis » Sat Feb 09, 2013 7:41 pm
Just checked mine on dipped beam and flash is halogen while main beam opens up the xenon as well - see the line on the wall to the left. My build sheet has S522A - Xenon light
Dipped-
Flash-
Main beam-
2004 E53 X5 4.4i Sport
Post by X5Sport » Sat Feb 09, 2013 9:36 pm
Perhaps BMW were being a bit disingenuous with their use of the term 'bi-xenon' in that it is used for both dip and main beam?
X5LeMans
Post by X5LeMans » Sun Feb 10, 2013 1:10 am
Option 522, which is listed in the sticky as Bi-Xenon
Mine looks just like Psychosis, with three clearly different beam patterns.
It really shows up going down tight country lanes. The Xenon main beam lights up both hedges and trees to a much greater extent that the halogens, which seem more like spot lights. All put together its a pretty nice combination.
I'll try and get a few pictures up next time I'm out at night.
X5LeMans
Post by X5LeMans » Sun Feb 10, 2013 1:14 am
Any chance that BMW coded your car wrong? 522 should be the bi-xenon units on a facelift.
Wonder if there is any obviously visible wiring differences, visible part numbers etc, to know for sure? More than happy to take photo(s) if you like.
I don't have a scanner / obd2 reader at the moment, so cant give any clues to how my coding is set right now.
PS, I had BMW print off my spec sheet, they just said 522, I tried the Vin Decoder link, it said S522A
psychosis
Post by psychosis » Sun Feb 10, 2013 8:49 am
My code is just off the vin decoder site.
jaynana
Post by jaynana » Sun Feb 10, 2013 2:52 pm
[quote="X5LeMans"]
i'm sure bixenon must be pretty cool!
i guess if u have 522 u have it.
said that - for clarity, having 3 different beam patterns does not mean u have bixenon.
i have 3 beam patterns, although its def not bixenon:
1. dipped beam - xenon only
2. flash - halogen only
3. while on dipped beam flash or go for high beam - xenon + halogen
so 3 beam patterns. but not bi-xenon.
that's why pictures are hard to tell by.
therefore, if u don't have 522 coded i would seriously doubt if u have bi-xenon.
only way to tell might as x5sport suggested to  go in front of the car and cover the halogen with a cardboard  and ask a mate to change lighting mode.
X5LeMans
Post by X5LeMans » Sun Feb 10, 2013 5:59 pm
Jay,
If you "flash" with dip on, you get dipped xenon + halogen.
If you go Main beam, you get everything.. So I guess what I mean is you get 4 beam patterns
1) Lights off Flash - Flash / halogen only, no dip/xenon
2) Lights on - Dip xenon only
3) Lights on Flash - Dip mode xenon + halogen flash
4) Main beam - Main beam mode xenon + halogen as well
I thought in your last post you said you had option S522A which is why I wondered about faults, or miscoding.
You can see on Psy's picture, in the top picture the "white" xenon light dip only reaches half way up his gas/electric meter, and on his last picture the xenon's opened up, so the white xenon light gives the very sharp distinct light all the way above his meter boxes on the wall, and half way up the window at the back.
As I said, I'm more than happy to take a look at the lamps to see if there is any obvious part numbers that might better ID them. If its just a coding issue, if you have the same physical lamps perhaps you could get them enabled for main beam too? Seems odd that BMW would put S522A on your spec sheet, but end up with different lights?
To be fair.. When I bought the car. All I cared about was having xenon at all, as my old E39 had it, and I've kinda grown used to it... Bi-Xenon was just a bonus :)
Cardboard would work too.. On my car the cardboard test still shows bi xenon. I don't think there is any difference between using headlight mode "A" and normal "on". Pretty sure the bi-xenon does it's job in both list switch modes. I've been using "A".
Go beat up BMW and say they fitted the wrong lights :( !!.. Not they they will like change anything on cars the age of our E53's.
jaynana
Post by jaynana » Sun Feb 10, 2013 6:15 pm
that made me want to go out and check, - man you're right!!
it IS 4 beam patterns not 3, so i have bi-xenon as well!! hurrahh lol
it only works on full beam not on flash
sorry yes mine's 'S522A'.
X5LeMans
Post by X5LeMans » Sun Feb 10, 2013 8:05 pm
The extra light seems to really help light up overhead signs. But I find it hugely helpfull on narrow country lanes as it lights up the hedges so much better than the non bi xenon lights.
So you found out bi xenon doesn't activate in flash mode :). Next time your out try driving a little with dip plus flash the difference is massive.
I could be wrong but I believe the halogens have a tighter flash spot than halogens designed for main beam. So the xenons give a great main beam and the halogens are aimed to give a brighter center spot directed at the road ahead.
Anyway much better beam patterns then my old standard xenon e39
Be your happy now even though its something you've already got used to :).
Post by X5Sport » Sun Feb 10, 2013 8:28 pm
The inboard pair are designed to function as spotlights and to have a tight beam aimed to provide long range in the centre of the pattern - exactly as you are seeing.  Same as the generations of cars that either had, or had fitted as extras, good old Hella or Ring or PIAA type 'spot kits' in the 70's - 90's.  Same job as the main beams were pretty dire back then.  I remember swapping to H4 bulbs very quickly after the came out as they were a vast improvement.  100W versions were even better.  8)
jaynana
Post by jaynana » Sun Feb 10, 2013 11:16 pm
[quote="X5LeMans"]
don't think i've ever used it other than in flash mode. next time i know how to flash lol
Rusty
Post by Rusty » Mon Feb 11, 2013 12:24 am
[quote="jaynana"]
Having just installed a pair of 55w HID's to replace my faulty 35w OE unit (thanks Kkodal for the kit) I did wonder why there was a pair of wires that disappeared into the HID lens assembly.
It certainly sound like this may be for the shutter control as I too have the S522A option fitted.
If I get a chance, I will have a beam pattern check too.
Runabout - E92 3 Series Coupe
X5LeMans
Post by X5LeMans » Mon Feb 11, 2013 1:56 am
As long as you have the shutters wired up I don't see any reason they wouldn't work after the 55watt upgrade. I imagine that will be pretty bright.
As the halogens appear to be fill in spots rather than full main beam you'll probably want to get those bi xenon shutters working :).
Rusty
Post by Rusty » Wed Feb 13, 2013 11:15 pm
Definitely much brighter with the main beam on compared to dipped & flash.  Real easy to see with the 55w'ers.
The upgraded lights are def worth doing as you can actually see the road.
