Advice on isolating a subwoofer?
I've finally decided to go for a dedicated subwoofer at home, and have just ordered a BK XXLS400 FF. My one concern is not to upset the neighbours with whom I currently have a good relationship, with vibrations transmitting through the walls and floor. I thought there'd probably be some audiophiles on this site who could give sensible advice as to how best to isolate it?
The property is terraced, and the room the SW will go in is 20ft by 20ft with neighbours immediately beneath (wooden floor) and on both sides (brick walls). I'll be putting it on spikes but understand that some use isolating foam, however can't find anything that isn't dog ugly and don't know if it will be necessary anyway?
Any advice gratefully received!
Spare: VW Golf V5
History: TVR Chimera 5.0
Spare: VW Golf V5
Re: Advice on isolating a subwoofer?
As subs use the floor or walls as a soundboard you may have to keep the bass wound down a bit or you may not be very popular. I lived in an end of terrace a few years back, and had a Jamo sub which used the floor as the sound board and did need to be kept low or my neighbours got annoyed. Bass seems to travel well!!
If it's a wall firing type then turning it away from the wall, or moving it a few inches further away can help limit any nuisance.
Good luck though....
Think I'll put it on spikes and granite to stop vibrations feeding directly from the sub box to the floor, and as you say keep it turned down. Look forward to cranking it up when neighbours are out though! O:-)
Spare: VW Golf V5
Spare: VW Golf V5
Yob !
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
2012 Audi RS4 (B8)
Previously :
Put the granite on some foam so it reduces the amount of sound transfer down.
Runabout - E92 3 Series Coupe
I needed to dissipate some noise/vibration from a powerful water pump, I used some acoustic foam and it worked a treat BUT it was out of site.
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Current
Jaguar XF
Previous
BMW X5 3.0D
- Steamyrotter
Move??
Deafen the neighbours?
Insert ear plugs in their ears when they are sleeping?
(admittedly probably one of the more creepy suggestions???
Please note...
Please note...
[quote="Rusty"]
Thanks. What sort of foam would you suggest? I'd looked at the Auralex Subdude (cool name eh? Not) but it's butt ugly. Something that Reusch also alludes to. Are there any foam options that aren't? I'm currently looking at using 10 or so Foculpods beneath the plinth...
Spare: VW Golf V5
Spare: VW Golf V5
[quote="Steamyrotter"]
Move??
From what I gather, if I crank this baby up, that's exactly what will happen, if I don't bring the house down that is. Problem is that I would also deafen myself in the process, which kind of defeats the purpose ...
Move??
Spare: VW Golf V5
Spare: VW Golf V5
Bose QC headphones - then you can ramp it up all you like!!
Bose? Get some proper ones.....Sennheiser... >:D. Bose indeed
:nono:
:nono:
Agreed - already got the Sennheisers - look a bit industrial rather than cool, but same as around half the commentators and DJs seem to use. Block surrounding sound out very well and very good SQ. Don't make the earth shake though!
Spare: VW Golf V5
Spare: VW Golf V5
