Air suspension topic locked?
Raj
Post by Raj » Wed Jul 11, 2012 1:09 pm
Not sure why the topic by James is locked so will reply here.
The FSR is probably in its way out hence being a bit random with its power drain.
As for the alarm, pressing the button twice will deactivate the interior sensors I believe so sounds like one of the sensors internally may be playing up or something is triggering the interior sensor when active.
Air suspension could be anything, from a dodgy sensor (so not stopping pump as it thinks the suspension is sat lower than it is), air pump getting stuck open or maybe the control module.
james8whippy
Re: Air suspension topic locked?
Post by james8whippy » Wed Jul 11, 2012 1:28 pm
Hi Raj,
Thanks for your reply.
Sorry I must of pressed Locked by mistake! I have the post unlocked now.
Are the interior sensors easily replaced? Is there anyway I can find out which sensor is at fault? or what is causing the alarm to go off.
I have DIS, INPA etc if that helps?
In terms of the air suspension is there a way of troubleshooting it? Do you think it's unusual that it only rises when the car is turned off and locked. I would of thought it would turn off the power to the pump etc if the car was locked?
thanks
James
james8whippy
Post by james8whippy » Fri Mar 22, 2013 10:31 am
For people stumbling across this post in the future I went ahead and changed the FSR 3 weeks ago and so far the problem is resolved!!  So happy
It's so strange that a FSR can not only cause battery draining issues but also it can mess up the suspension!
But that's BMW electrics I guess!
