Hello from sunny Suffolk
Chompers
Re: Hello from sunny Suffolk
Post by Chompers » Wed Mar 27, 2013 8:31 pm
My 20's didnt have RFT's and I have to say I have never seen an e53 shod with them 19",20" or otherwise. BMW approved RFT's are marked RSA followed by a * (5 point star) for info and factory fit 20" tyres (non RFT) were Michelin Diamaris.
Current
09/59 e61 520d MSport Touring Business ED - Platinum Grey / Cream Beige Leather
Previous
06/06 e53 X5 4.4i V8 Sport - Titanium Silver / Black Nappa Leather
Post by X5Sport » Wed Mar 27, 2013 9:44 pm
Whoever bought mine got a brand new set of Bridgestone RFTs on 19" - straight off a new X6.
And to the OP...... :hi:
Johnell
Post by Johnell » Wed Mar 27, 2013 9:52 pm
Thanks for the welcome guys.  I'll check to see if the 20"s have got run flats fitted, I'm hoping it has because it means I  could tone the ride down a bit by fitting normal tyres.  I wasn't aware of the markings Chompers so thanks for the heads-up.
I appreciate the info re the caravan cooling and towbar Don.  The caravan is a 2008 Coachman Pastiche 530/4 which has got 2 plugs, do you suggest I fit a single socket on the car and use a splitter lead?
2006 3.0d Sport. Black Sapphire Metallic. Black Nappa. TV. Nav. Climate, Comms and Sport Plus packs. 20" wheels
Ask the question and you are a fool for 5 minutes.....don't ask the question and you are a fool for life......
Chompers
Post by Chompers » Wed Mar 27, 2013 9:56 pm
Maybe so but as far as I'm aware RFT's were not fitted to e53's as std from the factory?
Current
Previous
Rusty
Post by Rusty » Wed Mar 27, 2013 10:46 pm
Welcome.  A good spec indeed.
I was a little concerned with the 20's on mine initially, but after replacing all 4 tyres for the Toyo Proxies the car was transformed.  I would definitely stick with them as you will indeed de-value the car by downgrading to 19's
Is the dealer fitting the Westafilia or whatever it is tow bar with dedicated electrics? This setup would ensure the car adjusts its settings to deal with a van.
Enjoy the car and this site
Runabout - E92 3 Series Coupe
Chompers
Post by Chompers » Wed Mar 27, 2013 10:54 pm
[quote="Rusty"]
Good point Rusty, also make sure the relay (think this is a BMW part) is fitted to turn off the rear PDC when reversing  ;)
Current
Previous
Johnell
Post by Johnell » Wed Mar 27, 2013 11:08 pm
Thanks Rusty, I'll chat to the dealer about the relay.
BTW, which Proxes did you fit?
Don Coffey
Post by Don Coffey » Thu Mar 28, 2013 7:25 am
Hi John, whether or not to fit the single plug I suppose depends on how long you intend to keep either the X or van.  I'm not 100% sure when the 13 pin plugs became standard in the uk but think it was about 2010. It must also be possible to change the twin plug to a single in the future if it becomes an issue.  In the same way it must be possible to change the vans twin leads into a single. The single plug is a lot more secure and gives a better connection, reliability.
Don
Johnell
Post by Johnell » Thu Mar 28, 2013 8:49 am
[quote="Don Coffey"]
Don[/quote]
The intention is to keep the car for a few years, the van may be changed sooner than that if the other half decides she wants an island bed!!!!!  ::)
I'll have a chat with the van dealer to see what he recommends but from what you are saying the single socket used with a splitter lead is the way to go.
John
lezmtaylor
Post by lezmtaylor » Thu Mar 28, 2013 11:15 am
To put the cat amongst the pidgeons, i had 20's on, then 19's and then got a set of 17's with new michelins for £50 off ebay, have to say the 17's give a far superior comfort ride and I am towing a Coachman Pastiche 470/2.
I always thought if the car was factory fit towbar extra cooling was fitted at the factory.
Don Coffey
Post by Don Coffey » Thu Mar 28, 2013 11:24 am
[quote="lezmtaylor"]
On the E70/71 the extra towing capacity is an option. My car has an after market tow bar albeit oem. My car has a rating of 2700kgs. More than enough for any caravan legally towable on UK roads.
Don
Rusty
Post by Rusty » Thu Mar 28, 2013 11:42 pm
[quote="Johnell"]
I have the Toyo Proxy ST's which I think have now been superseded by the ST2 but don't quote me.
I am quite a low mileage user but I have been suitably impressed by them, even in the snow and ice.  They are quiet when cruising, not as hard as Diamaras and look the part too.
Hope that helps.
Russ
Johnell
Post by Johnell » Fri Mar 29, 2013 12:14 am
Thanks Russ, I'll be researching tyres more thoroughly in a couple of months so will bear the Toyos in mind.
Jamee
Post by Jamee » Fri Mar 29, 2013 8:02 am
Welcome mate, sounds like a nice specced X5 you have bought, I agree with the tow-age, get the single plug and splitter at the mo, as if you do indeed change the van, it will likely have the single plug attached as standard.
look for ward to the pics.
Black BMW E70 35D
Previous:
: Tuned Black E53 3.0D Sport
: Tuned and custom E46 facelift BMW 330ci clubsport in estroil blue
Johnell
Post by Johnell » Fri Mar 29, 2013 2:49 pm
Cheers Jamee, I see you are fairly new too....it's a great site isn't it?
