X5 E53 Front parking sensors part numbers
willos
Post by willos » Fri Mar 22, 2013 11:01 am
Just taken my X5 back to the indy dealer as the engine light was on and the parking sensors not working.
Diagnosed a MAF and front middle sensor faulty.
Of course neither covered by warranty (bit of a pathetic set up but i wont go into that)
As im no stranger to 4X4 servicing and faults (still have my p38 rangie) im replacing both myself as i dont trust anyone to do the job properly without leaving me with a big hole in my pocket.
I have a late 2003 petrol 3.0  , E53 non facelift.  Are the part numbers different for the middle and the side sensors on the front bumber.    Also can i take them out without taking the bumper off as the stick out like a sponge pudding.
Re: X5 E53 Front parking sensors part numbers
Post by Horizon » Fri Mar 22, 2013 5:18 pm
The outer fronts are the right angle type, the centre 2 on the front, and all the rear 4 are the straight ones. I know on the facelift it's bumper off. Not sure about pre facelift.
I used this seller off eBay.
http://www.ebay.co.uk/itm/BMW-PARKING-S ... 2a2a0b279c
jaynana
Post by jaynana » Fri Mar 22, 2013 7:52 pm
realoem is your friend for part numbers.
in the pre facelift i believe you can replace the pdcs without the bumper off. if you look in the above diagram the item 10 might be removable without the bumper off.
kkodal78
Post by kkodal78 » Fri Mar 22, 2013 8:32 pm
Corner ones you can replace it without damaging anything but the center ones you might want to have spare pdc covers which are 5er from the dealership and you can pry the old one out and replace it. It takes 5 mins to do so.
willos
Post by willos » Sun Mar 24, 2013 5:42 pm
Thanks guys
Raward
Post by Raward » Sat Apr 20, 2013 5:58 pm
Hi Guys
I've just bought an X5 2003 3L sport.
Suddenly realised that the right rear and right front sensors are knackered.
I've easily removed the R rear and got the correct part number & ordered new from ebay £22.
I'm going to take it to a local lad to replace the front right sensor but unsure from the posts which would be appropriate.
Would this be the correct sensor to buy?:
http://www.ebay.co.uk/itm/BMW-X5-E53-X3 ... 4ab814199d
Many thanks for any advice.
Raward
2003 X5 pre-facelift
jaynana
Post by jaynana » Sat Apr 20, 2013 9:26 pm
Welcome aboard, hope u find the car 'rewarding'.. :)
Presume its a facelift?
That would work if u r looking for a corner pdc. The centre ones are straight, not angled.
Raward
Post by Raward » Sat Apr 20, 2013 10:11 pm
Thanks Jaynana,
Feeling rawarded already!
This one will annoy you - I've looked on Wiki but how do I know if I've got a facelift version?
I could supply my VIN if that helps....
Thanks again
Raward
Raward
Post by Raward » Sun Apr 21, 2013 7:05 am
Ok
I've worked out now that mine is Pre fracelift 2003.
Which sensor now? Right front corner.
Thanks again
Raward
jaynana
Post by jaynana » Sun Apr 21, 2013 7:59 am
Its the diagram mate, in post 3.
Ur post says its a front right. THere are 4 pdcs.
If its right corner its part 12 in the diagram, if its right centre its part 4.
Hth
Raward
Post by Raward » Sun Apr 21, 2013 10:23 am
Thought so but if in input my VIN on the site it's not so clear.
I will order and keep you updated.
There seems to be debate as to whether or not you need to remove the bumper to replace the front corner sensors on a pre-facelift E53.
Has anyone here done it without removal and if so how easy is it?
Thanks once more.
Raward
