Changed Brake Discs & Pads - Light stays on
Steve Blackdog
Post by Steve Blackdog » Thu Aug 22, 2013 10:45 am
Hi Folks
Anyone know why my "Check brake linings" warning is still coming up after I've changed my worn rear brake discs and pads and replaced the wear sensor?
And is there anything I can do about it?
Steve
Sanj
Re: Changed Brake Discs & Pads - Light stays on
Post by Sanj » Thu Aug 22, 2013 11:07 am
Replace both sensors?
Lummox
Post by Lummox » Thu Aug 22, 2013 11:33 am
Steve,
I have had this numerous times on different models of BMs from that era. Take the car for a drive and the warning will dissappear, sometimes after about a mile but sometimes it can take a couple of miles.
Craig
2004 54 plate 4.8is X5 E53 facelift in Carbonswarz-metalic.
Ubatoid
Post by Ubatoid » Thu Aug 22, 2013 4:51 pm
You need to reset the warning. Turn key to ignition No.2, wait 30 seconds, turn off and then start. Should do the trick.
2002 4.4 cooking on gas
Denis O
Post by Denis O » Thu Aug 22, 2013 5:22 pm
[quote="Ubatoid"]
I seem to remember that with the procedure you need to have the door open. I could be completely wrong and you should put this outburst down to age  :P
05 Mercedes SL350
Steve Blackdog
Post by Steve Blackdog » Thu Aug 22, 2013 6:48 pm
Thanks chaps:
@ Sanj
I've only done the rear discs and pads as the fronts have plenty of life left in them.  There's only one sensor on the rears (drivers side).  Do you mean I should replace the front anyway, or am I misunderstanding you.
@ Craig - I've done about 500 miles since doing the brakes.  I was hoping it would go out of its own accord!
@ Ubatoid and Denis O
I've just been outside switching the ignition on and off, door open, door closed and no luck, I'm afraid.  I think the neighbours think I've gone a bit mad.
I guess it's not beyond the realms of possibility that the new sensor (New Generation) is a dud.
Any other thoughts?
Steve
Lummox
Post by Lummox » Thu Aug 22, 2013 6:57 pm
Things to check.
You haven't re-fitted the old sensor by mistake.
You have pushed the plugs together fully and they are the same type of plug
You haven't damaged the wire when fitting the sensor.
It is the correct sensor and it is located in the pad correctly
Your nearside front calliper isn't seized and worn the outer pad down and tripped that sensor
Craig
Steve Blackdog
Post by Steve Blackdog » Thu Aug 22, 2013 7:11 pm
Thanks Craig - very helpful.
I'm just wondering..... I wonder if it was not the rear sensor that was triggering the "check Brake linings" warning.  I automatically assumed it was the rears because I had them down on my "things to replace in next 5K" list.
Just before the light came on, I'd had 4 wheel alignment carried out. Is it possible that when they were messing with the tracking on the front wheels they damaged that sensor?  and that I have been looking for the answer in the wrong place?  I had the brake fluid replaced and some rear suspension parts at the same time.
what d'ya reckon?
Ubatoid
Post by Ubatoid » Thu Aug 22, 2013 8:08 pm
Yes, I am now remembering having to give the brake pedal some pumps while the ignition is on and then switching off and back on.
Steve Blackdog
Post by Steve Blackdog » Thu Aug 22, 2013 9:13 pm
[quote="Ubatoid"]
Are you sure I'm not on Candid Camera??
I'll give it a try - not too hopeful :)
Lummox
Post by Lummox » Fri Aug 23, 2013 12:36 am
It may be worth while pulling the nearside front wheel off and having a poke around. I think it unlikely that they will have damaged anything but you never know, a spanner may have slipped or a wrong move with the acetylene torch if they had to warm the nuts up on the track rods
craig
ITBarbie
Post by ITBarbie » Fri Aug 23, 2013 7:48 am
I had to do the reset a couple of times and did the drive and it eventually worked.  Try it one last time like this http://www.ehow.com/how_4844864_check-brake-lining-message-bmw.html#page=0
2004 Sapphire Black 3.0d SE
MODS
Denis O
Post by Denis O » Fri Aug 23, 2013 8:07 am
[quote="ITBarbie"]
Thanks Penny. It appears point 1 on your link means that I'm not that old  :dance:
05 Mercedes SL350
pvr
Post by pvr » Fri Aug 23, 2013 9:22 am
Never knew about that door thingy, but the I replaced the pads before the light came on.
911 50th anniversary -
Steve Blackdog
Post by Steve Blackdog » Sat Aug 24, 2013 9:49 pm
No luck.  Tried all possible options of the reset procedure.
I think I need to take Craig's advice and poke around behind the front wheel.
Thanks again :)
Steve
