Phone
Phone
Hello all,
This will sound stupid but I have never done this before can I connect my I phone to my car for phone calls music etc, I have had a look through the book and pressed buttons but I haven't got a clue what I'm
Looking for or doing
Cheers guys
Cheers guys
Re: Phone
Music will need a separate connection as the OEM Bluetooth is only V1.1 which doesn't support it.
The phone should work via Bluetooth but you may need to delete all existing pairings before you can pair your own phone to the car (it only allows 4 pairings before refusing more).
Note that not all phones work properly and certain functions are not available at all depending upon phone model.
You should have a book for it in the car, plus the car's PIN.
Re: Phone
Have a look at this thread to see if it helps. Replies 11 & 13 may help as well.
I assume you have all the right manuals including the Bluetooth one? You also need the 4-digit Bluetooth PIN for the car....do you have that? I think the pairing button is in the armrest area (?).
It is possible the BT module is down or has been removed. It should be in the left rear cubby if memory serves, and mounted at an angle at the bottom of the cubby.
- Steamyrotter
Re: Phone
Correct.
Where are you (roughly)
Someone near you may be able to assist and or scan car.
Correct.
Please note...
Please note...
Re: Phone
[quote="Steamyrotter"]
Correct.
I have the same problem....whereabout are you steamrotter? I m in Romford Essex..
Correct.
- Steamyrotter
Re: Phone
[quote="aneeque27"]
Correct.
About 200 miles from you i'm affraid..
Correct.
Please note...
Please note...
Re: Phone
Anyone in Gloucestershire?
