Angel Eye Bulb replacement
rickyclean
Re: Angel Eye Bulb replacement
Post by rickyclean » Mon Nov 02, 2015 10:26 pm
[align=center]BMW e70 X5 Headlight Removal Pre LCi (2007)[/align]
A few weeks ago the off side headlight of my X5’s angel eyes bulb blew. After some extensive research, a lot of prodding around the engine bay and the help from the fine people of XDrivers.co.uk it soon became clear that this particular task was a biggie.
Suffice to say, as you will see from the picture below the bulb in question is hidden behind a panel, with no hope of access when the headlights are in place.
Rear panel for access to angel eye bulb:
This is a step-by-step guide that I hope will be useful to those who need to deal with this task. Please note that I am not a mechanic and should you choose to undertake this task with this guide you do so of your own volition.
Firstly you need to know that to remove the headlights you will need to remove the front wheels and the front half of the wheel arch liners so you will need the following:
  • 2 tonne or more hydraulic car jack (I used a 2.5 tonnes jack to be sure)
  • 2 tonne or more axle stands (I used 3 tonne ones)
  • Wheel chocks x4
  • Socket Set (8mm and 10mm)
  • Torques socket set - 2.0mm and 2.5mm
  • Philips screw driver
  • Flathead screw driver
  • End cutting pliers
  • Plenty of containers to place the various bolts and screws so that they are neither lost or mixed together incorrectly
  • A bucket
  • Patience!
Step One:
Position the car on a flat, even and strong surface with plenty of room for you to work in. Loosen slightly the bolts on the front wheels so that you can unscrew the bolts safely once the car is jacked up. Place wheel chocks on either side of the rear wheel s to help prevent the car from rolling forwards or backwards.
Jack up the car on jacking point 1 of the below illustration to a height that means the front wheels can rotate easily. Place your axel stands on jacking point 2 behind the front wheels. Have the axle stands set to a sufficient height to allow the front wheels to rotate and have enough clearance for the wheels to be removed. Be sure the axle stands are positioned correctly on the jacking points.
Step 2: Near side Headlight
  • Remove the front wheel to gain access to the inner wheel arch lining.
  • You will see that the lining is split in 2 halves (front and back. You will only need to remove the front half section.
  • Firstly you will need to remove the front plastic wheel arch moulding that are held in place by plastic “bolts” as pictured below
  • With the flat head screwdriver lift the plastic bolt and then remove by hand  (these should be very easy to remove)
    • Image
      Once all the bolts are removed then pull the moulding out of its placement
      Step 3:
      • This step is to remove the front inner wheel arch lining.  You will need your 8mm socket 10mm socket, torques socket and end cutting pliers
      • There are multiple 8mm bolts that you will need to undo inside the wheel arch and one 10mm bolt.
      • You will also need to undo two 8mm bolts that hold the lower part of the Bumper/spoiler and the wheel arch lining.
      • There is also a large Philips screw that will need undoing (the screw undoes but does not come out).
      Next you will need to remove 3 plastic securing pins, 2 of which secure the lining around the brake duct, the other in located near the suspension joining the front and rear linings. You will need to use your end cutters very carefully as illustrated below:
      Finally there is a 2.0mm torques screw to remove from the lining as seen here:
      Step 4:
      Now you should be ready to remove the wheel lining. This is a relatively easy task and should come out easily. If it doesn’t then you haven’t removed all the necessary bolts etc.
      To remove the headlight you will need your torques set (2.0mm and 2.5mm). As shown below there are 4 connecting points where 4 long 2.0mm torques screws are located. Points 1 and 2 are easy to locate and remove however points 3 and 4 are more difficult to reach.
      Once you have removed the 4 screws you will then need to remove a 2.5mm torques screw from underneath the light (located under the plastic connecting chassis arm). Next to that is another torques 2.5mm screw attaching the front wing to the plastic chassis connecting arm. You will need to remove this as well as you will need to have flexibility in the wing to get the headlight out (see below picture  - note that is of the offside wing and not the nearside but you will need to do this with both wings).
      You will now be able to remove the headlight, You need to be extremely careful as the space is limited and you can easily scratch the headlight lenses. As you will see from the picture below you will need to move the cabling attached to the chassis and remove bubl access caps for the main beam and high beam bulbs.
      Your headlight is now removed!
      Step 5:
      Copy all the steps again for the offside headlight, however this is even harder. The reservoir for the water jets will be in the way as will the pipe for the headlight washer jets will be in the way (see pictures below).
      To remove the washer jet pipe you will need to unclip it from the plastic chassis connecting arm.
      Once you have unclipped the pipe you will need to disconnect it from the headlight washer jets pictured below. Make sure you have your bucket handy to enable you to drain the washer jet fluid cleanly and safely and make sure you have the pipe out the way like below.
      Now you will need to unscrew 3 of the  front wing screws as pictured below and position a tool like the wrench in the picture to help lift the wing up to aid the removal of the headlight.
      You will then need to unscrew the 8mm bolt pictured in the next 2 pictures:
      Removing all these bolts and screws means you have more flex in the wing allowing for the headlight to come out more easily.
      Now you should be able to remove the second headlight!
      Top tip is to make sure the bulbs you have replace work before you put everything back...
      Good Luck!
    Post by Horizon » Mon Nov 02, 2015 10:44 pm
    Great write up
    rickyclean
    Post by rickyclean » Mon Nov 02, 2015 10:58 pm
    [quote="Horizon"]
    Great write up
    app_master
    Post by app_master » Mon Nov 02, 2015 11:20 pm
    Thanks RC that was an epic write up. Much appreciated.
    I will circle out a Sunday morning in my calendar soon and get cracking. Will report back then.
    I am guessing, but you seem to have avoided the need for a plastic rivet and tool for re-fixing the wheel arch panels. I am not sure if I have that option, pretty sure they are a once-use rivet. I will investigate further so I am prepared, just in case.
    makx5
    Post by makx5 » Wed Nov 04, 2015 1:30 am
    Quality write up ,
    rickyclean
    Post by rickyclean » Wed Nov 04, 2015 7:58 am
    [quote="app_master"]
    Pleasure sir. The rivets for my car are re-usable however mine is an SE, so if yours is an M Sport then it may be different. Let us all know how you get on!
    rickyclean
    Post by rickyclean » Wed Nov 04, 2015 5:16 pm
    [quote="makx5"]
    Quality write up ,
    Thanks!
    app_master
    Post by app_master » Tue May 03, 2016 1:32 am
    Hi Ricky.
    Finally found some time to get on to this. Your above step instructions were invaluable, although I did need the plastic rivets for my wide wheel arches. I only had the morning so got one side done yesterday. Also did the HID low beam upgrade while in there. 1000% improvement over the halogen. Here it is...
    Post by X5Sport » Tue May 03, 2016 6:07 pm
    Great write up......but what a palava and faff!  Surely there had to be a better way but manufacturers seem to 'design to build' rather than 'build and maintain'.
    The engineer in me thinks this design is just wrong on so many levels.
    No wonder dealers charge so much!
    app_master
    Post by app_master » Wed May 04, 2016 12:58 am
    No, every damn level...  :))
    I suspect this is why this particular headlight assembly for the X5 was short lived.
    This dilemma of "changing the damn light-bulb" was another reason why I put it off for nearly 6 months since buying the upgraded bulbs. Anyway I now intimately know quite bit about the wheel arch assembly, so now that I am halfway through my upgrade I better keep going. I'll post some final pictures of all my light upgrades once complete. I am happy that I am doing it though. Thanks.
    rickyclean
    Post by rickyclean » Sat May 14, 2016 2:16 pm
    Hi Ricky.
    Blimey app_master that looks the business. How complex was the HID upgrade? Glad the write up helped sir!
    RC
    app_master
    Post by app_master » Mon May 16, 2016 7:07 am
    Hey Ricky.
    The HID is basically a replacement of the low beam bulb, although you need to accommodate the ballast wiring harness. An easier option to consider is LED headlight bulb replacement, as there are many of these now available and can be a very close to matching the intensity of HID. Bonus is they will be straight plug-n-play install  (i.e. no harness etc). Example, I've been running these in my pickup for about 6 months now with good result; http://www.ebay.com.au/itm/50W-Car-Philips-LED-6400LM-H7-Headlight-Auto-Conversion-Kit-6000k-White-Bulbs-/172038364698?hash=item280e491e1a
    Update on my progress... I did complete the Angel Eye bulb upgrade and it lasted all of 1 day! FFS! As the rhs side bulb failed and the lhs side has now faded significantly. Should have known better than to rely on some obviously very ordinary ebay items, so now I have to do it again  >:( Although I will replace with better known or branded option (e.g. like "Lux") this time. The alternative "mtec" set I have and wanted to fit did not fit the housing.
    Next Option found: http://www.hids-direct.co.uk/20w-cree-b ... arker-kit/
    Not fitted "Mtec": http://www.hids-direct.co.uk/mtec-ver-4-9w-led-bmw-angel-eye-kit-e90-e91-pre-lci/
    Alternative "Lux": https://www.luxangeleyes.com/products/lux-e90-v6
    I will take photos of the HID setup too while back in there...soon...and hopefully not another 6 months away job. ::)
    rickyclean
    Post by rickyclean » Wed May 18, 2016 6:05 pm
    Please do take pics when you get back in there as that would be really helpful sir.  :)
    Sorry to hear about the failing LEDs, when I did my set up the day after the install I got an error message saying bulb failure, but the bulb was working fine. Not done it since, but I fear these after market solutions can throw a few wobblies.
    RC
    rickyclean
    Post by rickyclean » Thu Jun 23, 2016 3:11 pm
    So at the weekend, one of the new LED halo's failed... I am going to go spare if very 6 months I need pull apart the front of my car to replace these.
    Has anyone upgrade the headlights to Lci ones on a pre Lci car?
    app_master
    Post by app_master » Wed Sep 14, 2016 3:21 am
    Hi Rickyclean (and any others who come by here interested to know...)
    Finally changed these pesky parking bulbs again. 2nd time was much quicker by the way  :))
    Went with superior LUX branded version bulbs; E90 v6; https://www.luxangeleyes.com/products/lux-e90-v6
    They fit perfectly and shine daylight brightly.
    I'll post installed pictures of them if there's interest.
    Thanks again.
