I've been cleaning mine and want to remove it to check it but the top of the plug slides back and forth but I can't get it off. Don't want to break it so any tips appreciated.
Ps. All the you tubes I've seen cut the actual removal of plug and unit from the vid, which would actually be the key part of have thought!!!! Grrrr!!
How do remove the plug on the DISA valve?
Re: How do remove the plug on the DISA valve?
Figured it out and cleaned it up, what do you know? Power and smooth idle restored! Result
