webasto smoking and smell of fumes inside.
TimX5
Post by TimX5 » Tue Nov 25, 2014 9:41 pm
Having read up on when the webasto heater kicks in depending on.. (outside temp and engine temp ) mine seems to start up as it should , is it normal that it bellows out loads of smoke and stinks of fumes inside the cabin or should it burn cleaner , is it not igniting correctly any ideas please.
Tim
Re: webasto smoking and smell of fumes inside.
Post by X5Sport » Tue Nov 25, 2014 10:25 pm
Should burn cleanly after first ignition.  Sounds like it needs a bit of a clean firstly.  I think there's a how to on her somewhere.
TimX5
Post by TimX5 » Tue Nov 25, 2014 10:52 pm
Thanks Richard ill see if I can find the thread.
mikem
Post by mikem » Wed Nov 26, 2014 8:52 am
You shouldn't get any fumes in the cabin, the exhaust runs to under the F/N/S floor. Maybe it's cracked or has a hole in it ?
TimX5
Post by TimX5 » Wed Nov 26, 2014 1:46 pm
[quote="mikem"]
Yeh seen the exhaust and all is fine , I think it's just the amount of smoke it chucks out that you can smell it inside .
I went out last night in the car and a short distance from home I was in standing traffic , the webasto  kicked in and bellowed loads of smoke out and I could smell it inside , then traffic moved and we drove off.
Smeeagain
Post by Smeeagain » Wed Nov 26, 2014 2:02 pm
I'm wondering if this is causing the problem with the fumes I have in the cabin. I have searched on "webasto" and found 192 search results on here but have been through them all and found nothing on cleaning the unit - does anyone have any knowledge or links on how to do this? I found some stuff on youtube but is a different webasto unit
Robert
TimX5
Post by TimX5 » Wed Nov 26, 2014 5:17 pm
Smeeagain
Post by Smeeagain » Wed Nov 26, 2014 5:44 pm
perfect, thanks
Smee
TimX5
Post by TimX5 » Wed Nov 26, 2014 6:34 pm
[quote="Smeeagain"]
perfect, thanks
Smee
It'll go on the jobs to do list  :))  along with the glow plugs and relay,  I'm on holiday at Christmas for 2 weeks  :xmasgrin: so out with the spanners.
Smeeagain
Post by Smeeagain » Wed Nov 26, 2014 7:30 pm
I'd prefer you came round sooner than that please
Smee
TimX5
Post by TimX5 » Wed Nov 26, 2014 8:27 pm
[quote="Smeeagain"]
Smee
Have you got the same problem with your webasto  Smee or is it the manifold that's leaking.
Smeeagain
Post by Smeeagain » Thu Nov 27, 2014 4:41 pm
I see no smoke from the webasto but cant find a leak from the manifold either but we do have fumes in the cabin
Smeeagain
Post by Smeeagain » Fri Nov 28, 2014 12:12 am
actually thinking about this further (and working on the assumption that the Webasto is, in all other respects, working fine) I don't think that it is the Webasto as the fumes problem happens even when the temp is above 5 degrees, and if as I say, it is working fine, then it wouldn't be coming on above 5 and its its not on then it wont be producing fumes
Smee
Post by X5Sport » Fri Nov 28, 2014 10:53 am
Look at all of the door seals.  It might be coming in via the tailgate, or doors if there is a gap.
See if there are any missing or misplaced chassis bungs, especially in the wheel well that might be allowing crap into the cabin.  I can't remember if there any air vents (not a/c connected ones) in the rear quarter panels that allow air out.  If they are the 'flap' type then one may be stuck open perhaps?
Smeeagain
Post by Smeeagain » Mon Dec 01, 2014 5:40 pm
[quote="Smeeagain"]
turns out it is a cracked exhaust manifold
Smee
