'Max' blower switch fails to work
ssx5
Post by ssx5 » Mon Jan 05, 2015 4:10 pm
Tried to clear the screen on a cold morning by switching on the 'max' button, but nothing happens - no lights on the button. However, I can still get everything working by manually turning the fan up and lowering the temp settings. Just puzzled since the since 'max' switch has always worked previously.
chrisn7
Re: 'Max' blower switch fails to work
Post by chrisn7 » Sun Jan 11, 2015 5:27 pm
Welcome! I see your first post has not had a reply yet...
The Max button has two functions:
With engine on use in hot weather to cool the car fast: temp switches to 16C, maximum blower speed selected, both automatically. Outside air temp has to be above 5C, otherwise function doesn't work.
With engine off in cooler weather: use to stay warm for 10-15 mins. Outside air temp has to be below 15C..
To clear the screen, use the windscreen button, top right
