e53 d facelift : self level suspension inactive ?
chelsea
Post by chelsea » Thu Jan 08, 2015 5:10 pm
Hi all,
Started the wagon up at work and got "self level suspension inactive" warning on the diagnosis screen, checked all round the car and all was level so switched engine off and re-started and did not get the error message again on my way home, has anyone had the same happen to them before?
Cheers.
E53 X5 SE 2005
E70 X5 SE 5S (Shadow package)2009
Z3M 1998 special order (black and red interior)
Lotus Elise S1
Aprillia Caponord
2 Caravans.
fenj66
Re: e53 d facelift : self level suspension inactive ?
Post by fenj66 » Thu Jan 08, 2015 5:23 pm
ive had the message appear on screen once. there was no signs of a problem and its been fine ever since.
all i can think of was the car was parked with one wheel up a low kerb and that messed up the self levelling sensors somehow..
Post by X5Sport » Thu Jan 08, 2015 5:51 pm
Highly likely to be a false warning caused by the electrics.  One way of solving it is to let all of the warning lights cycle before cranking the engine.  If something fails to boot up correctly before the volts drop caused by cranking the engine then that error can appear.
Just another of the wierd things these cars do to worry owners even though nothing is wrong. >:(
chelsea
Post by chelsea » Thu Jan 08, 2015 6:15 pm
Thanks for reassurance chaps  :)
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
briankerrys47
Post by briankerrys47 » Thu Jan 08, 2015 10:27 pm
[/quote)Or battery  needs checking  O:-) O:-)
Holski
Post by Holski » Thu Jan 08, 2015 10:45 pm
I've had this a couple of times in the 7 years of ownership, it was the fuse.
X5-D-Sport
Post by X5-D-Sport » Fri Jan 09, 2015 7:56 pm
I get this error message several times a week.
Check your battery voltage.
this weekend, before you start the engine... turn all your lighting on for 20 mins (without engine), turn off lights, and check voltage -make a note of it.
A cold battery should be holding 13+ volts before start up, the same after lights on for 20 mins.
Start engine and check voltage again... the charging voltage should be 14+ volts - pressure the throttle peddle to 2,000rpm to check voltage.
An under voltage/knackered battery is...
Idle cold voltage of less than 13 volts
Cannot hold a charge voltage of 14+ volts when engine running
So, you will likely get spurious error messages with an under voltage battery.
A battery holding 10>11 volts will often be capable of starting the vehicle, but a load current of say a window or main beam will trigger failure report or endless error messages.
The suspension levelling error is NOT unusual.
The error could be caused by many things such as....
Under voltage battery
moisture in boot compartment causing false readings
suspension arm sensors moisture in electrical connections
Moisture in the sensor its self
or just stroppy PMT electronics..
The failure error will cease if you restart the engine - provided there isn't a failure.
Before you ignore the error messages, step out of the vehicle and see if it's level, and if the message pops up when driving give the steering a little wiggle at a slow speed & see if the car stays level as it normally would.
Again, check the battery voltages as a 1st step.
KGB BORIS
Post by KGB BORIS » Mon Jan 12, 2015 3:20 pm
defo check battery first! major cause of problems and odd errors, then if its anything to do with suspension and you only have the rear air bags id rip it all out and replace with coil spring kit for 200 pounds, end of that problem! ive done it and handles no different and will never cause me a prob again! plus if your compressor and other related parts are fine you can sell em on ebay and nearly pays for the coil kit.
