Hi, can anyone help please.
I had new pads fitted to the rear of my x5 fitted about 4 months ago, everything fine for about a fortnight. warning light appeared on dashboard "check brake fluid level" checked levels and found to be slightly low, topped up and all was well. further fortnight same procedure and so on. topping up water for washers and did not close bonnet correctly, driving up the road and bonnet flies up and breaks the windscreen, in my panic I stand on the breaks and I think ruptured rear drivers side flexi hose which seems to tell me this is where my slight leakage was coming from. X5 bonnet and windscreen now repaired at BMW approved garage. Mechanic informed me that he had noticed on dashboard "check brake fluid level" and duly topped up. driving car home and noticed very poor braking, contacted BMW approved garage and they told me to return car. car up on the ramp and inside of wheel and axle covered in brake fluid. I proceeded to take X5 to my own mechanic and informed him of findings and he duly replaced flexi hose but cannot get fluid to rear brakes. not sure if he followed the correct procedure for ABS/DSC can someone please advise has to correct procedure. sorry for long story 1st posting on this forum.
rear brakes getting no fluid on E53 2003 x5
Re: rear brakes getting no fluid on E53 2003 x5
Nasty!
If air gets into the modulator then it requires a special procedure to be used. The correct procedure requires the use of software to cycle the ABS systems. If the wrong process is followed it can wreck the modulator! If your mechanic does not have the BMW software then you need to get a BMW Dealer, or Indy, who has it.
ISTR it needs a vacuum bleeding system as well - Dealers have the special tool that does it all with the software driving the tool too.
Nasty!
I can't offer an opinion on why the air is still in but as a timely reminder about rear brakes on the E53 X5 I share with you and others the outcome of my recent "check brake fluid level" warning that nearly ended in disaster
http://xdrivers.co.uk/forum/index.php/t ... 227.0.html
Nasty!
