urgent help please (rear brake discs)
Hi all,
I am just in the middle of a rear brake swap on my facelift 05 diesel.
I do not seem to be able to get the disc off or away from the handbrake shoes, is there a knack or special tool for it?
getting dark.....many thanks
E53 X5 SE 2005
E70 X5 SE 5S (Shadow package)2009
Z3M 1998 special order (black and red interior)
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Re: urgent help please (rear brake discs)
Have you slackened the handbrake shoes off enough, little ratchet wheel inside the drum, you get to it through the little hole.
Sorry if you've already done this, but it usually catches a few people out.
Nearly forgot, special tool is usually a hammer or soft mallet of some kind, it's needed to get the disc/drum over the corroded bit where the brake shoes for the handbrake don't touch.
Use TWO big copper/soft hammers & wallop the disk/drum each side LOTS....
It will take plenty of clonking if the shoes are catching the drum inner - but it's often the way if the retainer springs are a bit soft with age.
While you're swapping disks, may be an idea to swap the handbrake shoes at the same time.
Get new springs & caps too fro Flea-Bay
Hi,
Thanks for the help chaps, I didnt realise there was the self adjuster to undo,did that and it just popped off with a tap of my plastic hammer, replaced the handbrake pads and disc and pads, disc wasnt too bad but at £114 for the full back set both sides then no point at all in doing bits.....one side done in an hour and a half ish, will do second one (driver side) tomorrow night after work.
will the brake lining light vanish when I have replaced the other side and sensor or do I need to plug my p.c. in to do it?
....Again...many thanks for the quick replies
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Lotus Elise S1
Aprillia Caponord
2 Caravans.
The wear warning will most likely go out once the vehicle gets no sensings for a few miles.
New wear sensor will clear the warning - or should.
thank you
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Lotus Elise S1
Aprillia Caponord
2 Caravans.
There you go Chelsea - Richard X5Sport is the keeper of the sacred knowledge.
I have learned that these machines LEARN of their new bits fitted and adapt accordingly.
Shame my lady friend is not as smart as my X5
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
Lotus Elise S1
Aprillia Caponord
2 Caravans.
And you even less so for picking her in the first place ....
MMMM got to agree,
Still, I will be keeping the X5 for sure, but a change of female is long over due.....
to find a NICE one is a rare thing - I seem to attract the weirdo women....
May have to become a Nepalese Trapist Monk lol
I'm fortunate in some ways.... No relatives or living family at all,
SO...
It's all about ME......
and a very small Christmas list :xmastongue: - which is... Me, Me AND of course.... Me
SO...
Well.....you do have the Xdrivers family too
Our Xmas lists are long, and expensive
Oh Sodding Balls,
I better get saving for my new family's presents then I guess.
This means I'm the waif that's been adopted lol
