Ccfl halo rings
Storm
Ccfl halo rings
Post by Storm » Thu May 14, 2015 6:15 pm
Hi I've just bought some halo rings for my x5 and was wondering if there was anybody that has fitted these before and are willing to do mine I'm in Northumberland but willing to travel a short distance and pay for your services thanks
X5-D-Sport
Re: Ccfl halo rings
Post by X5-D-Sport » Thu May 14, 2015 11:29 pm
There was a post about 8+ weeks ago on splitting the lenses of the reflectors, maybe worth a peep...
Steamyrotter
Re: Ccfl halo rings
Post by Steamyrotter » Fri May 15, 2015 12:08 am
I had CCFL in mine for a while but forever had interference issues esp with the front pdc sensors..
Traced it to the side light circuit running with a PWM signal....
This led to premature failure of the invertors..
I am now running smd led rings in mine and are infinitely better than the ccfl.
Much brighter, less current and no interference.
Would recommend them and only a few quid more than ccfl.
Depending on the age of your lights will determine how, or if, you can split them easily..
Pre 2003 would need heating to soften the sealant, whilst post will need cutting!!!
X5-D-Sport
Re: Ccfl halo rings
Post by X5-D-Sport » Fri May 15, 2015 10:13 pm
Good information !
I have a 2004 facelift, and fitted some mega bright cree LED halo lights that locate as a replacement where the normal bulbes located.
When fitting them, I did get a noticeable brighter light, bit its still dim as a bitch compare to the new BMW halo's on an X6 or other new vehicles.....
So, is there a brighter option for these units or is it that I have to open my lights up too, and dump the manufacturers halo's and replace with LED's too ??
Any thoughts guys ??
Regards
Grant B
Re: Ccfl halo rings
Post by X5Sport » Sat May 16, 2015 6:52 pm
Your lights are extremely difficult to open as the glue is different and doesn't soften in an oven.  A modelling saw is probably your only option.
There is nothing (as yet) on the market that will give you the same result as on newer BMWs.
Ubatoid
Re: Ccfl halo rings
Post by Ubatoid » Wed May 20, 2015 4:51 pm
2002 4.4 cooking on gas
