Gearbox oil
XDRIVER86
Gearbox oil
Post by XDRIVER86 » Mon Jun 15, 2015 10:28 pm
Decided to carry out an oil change on the X5s gearbox this week. I got the filter from BMW but they wanted around £120 for 5l of ZF longlife 6 and because I'm tight I had a look round the net but struggled to find it anywhere at a reasonable price. One last attempt I tried the Land Rover centre in Speke (LRparts.net) as the discovery uses the same box, £69.00 jackpot! Just a heads up for anyone else who's as tight as me...
kkx5
Re: Gearbox oil
Post by kkx5 » Mon Jun 15, 2015 10:39 pm
If its genuine zf, good price. 5L is not enough for pasive oil change never mind dynamic ...To do it the way it should be done you need 11L...
XDRIVER86
Re: Gearbox oil
Post by XDRIVER86 » Mon Jun 15, 2015 10:45 pm
I just did the partial change that ZF recommend, draining the sump and replacing the filter. I measured the oil I removed (around 4.5l) but that didn't include the bits I spilt and what was in the filter. I put back in just over 4.5l following ZF refiling guide.
The oil was ZF longlife 6, in genuine sealed  bottles.
kkx5
Re: Gearbox oil
Post by kkx5 » Mon Jun 15, 2015 10:53 pm
Check the level again, round 6-7L for static, 11-12L for dynamic..
XDRIVER86
Re: Gearbox oil
Post by XDRIVER86 » Mon Jun 15, 2015 10:58 pm
Will do, cheers
XDRIVER86
Re: Gearbox oil
Post by XDRIVER86 » Tue Jun 16, 2015 9:11 am
Was starting to panic a bit with the oil level. I checked with the ZF video https://www.youtube.com/watch?v=ZRrgmfM8VlQ and they say the box will take between 4-6l for the  ZF6HP26 I measured 4.5l ish that I took out and put just under 5 back in. The box had no leaks so I'm happy now...
