Blue connector in boot
cragglemiester
Post by cragglemiester » Fri Jul 31, 2015 6:18 pm
First off apologies for the noob-I-ness of the post but I tried searching with no joy.
Found this connector in the boot, is this the oem sub connector?
If so, could I use these wires to connect a low line convertor and install an aftermarket sub / amp.
I know I'd need a remote, Earth etc
Thanks in advance
Re: Blue connector in boot
Post by X5Sport » Fri Jul 31, 2015 7:26 pm
Connector for the electric backrest rake adjust option.  Will be one each side.  Not many cars had it, but mine did and very useful it was too  :)
cragglemiester
Post by cragglemiester » Fri Jul 31, 2015 7:34 pm
Aha, makes sense, take it plug and play then if I purchased a switch?
Thanks for the info
Post by X5Sport » Fri Jul 31, 2015 7:37 pm
And the motors, and the rest of the hardware.  Not available as a retrofit kit.
Occasionally come up on fleabay etc.
cragglemiester
Post by cragglemiester » Fri Jul 31, 2015 7:38 pm
Thanks buddy
Denis O
Post by Denis O » Sat Aug 01, 2015 5:25 am
My old 4.6 had this option.
I suspect a retrofit would be expensive and for the couple of inches movement, I wouldn't think it money well spent.
05 Mercedes SL350
