Start button just clicked - twice now
pvr
Post by pvr » Wed Aug 05, 2015 9:00 pm
Two weeks ago, drove to NL, parked up overnight and the next day the car just clicked when pressing the start button. It did it 3 or 4 times and I switched off the airco just in case, and it started absolutely fine.
Last week again, the car had been on the usual charger since I returned form NL and the first press of the start button, again just a click. Again, the airco button was on - I switched it off, tried again and starting fine. No other starting problems afterwards.
Car just ticked over 14k miles now and is always on a CTEC so battery fully charged.
Thoughts?
kjb1
Re: Start button just clicked - twice now
Post by kjb1 » Wed Aug 05, 2015 9:04 pm
loose connection somewhere on battery system!! starter not receiving full power.  Check the jump start point in engine bay also, as mine was loose here and causing starting issues similar to yours! get a spanner on the connection and nip up, to be sure.
Sent from my iPhone
pvr
Post by pvr » Wed Aug 05, 2015 9:09 pm
Interesting point - I always use the jump point for the ctek so could have got a bit lose. Will have a look at that first and follow the starter motor cables along to see if all is tight there.
Never been an issue, just a couple of times now in a few weeks. No error messages either.
Post by X5Sport » Wed Aug 05, 2015 9:09 pm
Problem with the ac system resulting in a starter inhibit?  Can't think of why though as it's not as if the compressor clutch is engaged all the time - or maybe that is the problem and the car sees the clutch as engaged at start when perhaps it shouldn't be.... ???
kjb1
Post by kjb1 » Wed Aug 05, 2015 11:05 pm
[quote="pvr"]
Sounds too familiar PVR, mine had no fault codes as such, and would just click! fail every now and then, started getting more frequent until point of failure and a tow to dealership ensued.  They found it straight away after seeing battery was healthy.  I split the connector down in the end and sand papered all the washer / nut / bolt etc, and got it all to fresh metal, then copious amounts of vaseline and never had a start issue afterwards.
Might not be your issue but always worth checking hey.  Nip up with a spanner, mine had a few mm of movement first time round, not much, but enough to cause issues.
Amazing that to look at and feel by hand all would seem well, but putting a spanner on it and getting a few mm movement on the bolt made so much difference!!
Sent from my iPhone
535dboy
Post by 535dboy » Thu Aug 06, 2015 3:43 pm
Part ex for a new one
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
pvr
Post by pvr » Thu Aug 06, 2015 4:12 pm
[quote="535dboy"]
With 14k on it? Think when I consolidate cars at some stage (i.e. when TVR's car gets here and there would be 7 then), that I would look at something completely different.
535dboy
Post by 535dboy » Thu Aug 06, 2015 4:14 pm
[quote="pvr"]
[quote="535dboy"]
An electric scooter? They'll be having your license of you soon given your recent big birthday.
In fact do you even have a UK licence?
Currently :
2012 Audi RS4 (B8)
Previously :
pvr
Post by pvr » Thu Aug 06, 2015 4:25 pm
Regrettably, yes - I do have a UK license as I was "forced" to swap mine due to insurance companies in the late eighties refusing to insure a UK car driven by a NL license holder.
I have been trying to swap it back but without a permanent address in NL it is not possible.
535dboy
Post by 535dboy » Thu Aug 06, 2015 4:26 pm
They will refuse to insure you anyway soon so hardly a major issue.
Currently :
2012 Audi RS4 (B8)
Previously :
pvr
Post by pvr » Thu Aug 06, 2015 4:27 pm
On topic - I have now tightened that bolt and will see if that helps. That hole point is a bit wobbly though, I might take it apart and use some of the KY that 535dboy left behind a few weeks back  :))
kjb1
Post by kjb1 » Sat Aug 15, 2015 10:57 am
[quote="pvr"]
whats the latest?
Sent from my iPhone
pvr
Post by pvr » Sat Aug 15, 2015 11:05 am
Uh.... I have not driven the car since  :o
Next drive is on Tuesday
535dboy
Post by 535dboy » Fri Aug 21, 2015 7:10 pm
[quote="pvr"]
And !?
Currently :
2012 Audi RS4 (B8)
Previously :
pvr
Post by pvr » Fri Aug 21, 2015 7:33 pm
Did not take it as I took the Golf - the weather was nice.
Had to drive through that sodding diversion in your village  >:(
