MOT Time
paulcoles88
MOT Time
Post by paulcoles88 » Thu Nov 26, 2015 8:18 am
So my X5 has her MOT this weekend, fingers crossed she passes :O although the headlight washers don't work but they aren't xeons just the standard halogen.. should this be okay? or am i going to have a nasty shock :(
Imy
Re: MOT Time
Post by Imy » Thu Nov 26, 2015 5:02 pm
You will be fine
Re: MOT Time
Post by X5Sport » Thu Nov 26, 2015 5:48 pm
MOT Manual only says they must work if fitted, in conjunction with HID (Xenon) or LED lighting units.  You should be fine.
Section 1.7, para 2 in case of any query.
paulcoles88
Re: MOT Time
Post by paulcoles88 » Thu Nov 26, 2015 9:37 pm
Thank you! you've put my mind at rest :)
You folks are so helpful :D
Thank you!!!
Insight G40
Re: MOT Time
Post by Insight G40 » Sat Nov 28, 2015 8:03 pm
Did you pass?
E53 Sept 2006 3.0D Sport
X5-D-Sport
Re: MOT Time
Post by X5-D-Sport » Sun Nov 29, 2015 1:37 pm
I have HIDs fitted to mine... and the light washers have never worked & it always passes...
Re: MOT Time
Post by X5Sport » Sun Nov 29, 2015 6:02 pm
You've been lucky with a tester not knowing the rules then.  It should fail.  Any good with lottery numbers?..... :))
Re: MOT Time
Post by Horizon » Sun Nov 29, 2015 6:08 pm
They never tested mine either, there's that many cars out there now with non projector headlights sporting HIDS, they must be going through the MOT test  too. The testers Nate even commented on the colour of the light 600K , saying he liked them and where did I get them.
paulcoles88
Re: MOT Time
Post by paulcoles88 » Mon Nov 30, 2015 9:13 pm
[quote="Insight G40"]
Did you pass?
I had to delay the MOT as i didnt get the bushes done quick enough :(
She was booked in for tomorrow but now the window has dropped and wont go back up so i dont know i think my X5 hates me
paulcoles88
Re: MOT Time
Post by paulcoles88 » Tue Dec 01, 2015 6:32 pm
She passed today but with a fair few Advisories...
Window still stuck down as they refused to look at it :(
Brake Pipe Slightly Corroded N/S & O/S Front
Headlamp Deteriorated but light output not reduced N/S & O/S
Tyre's close to limit N/S front, N/S & O/S Rear
Steering System has slight free play detected at steering wheel
Park Brake efficiency was only just met (17%)
So a nice little list to get sorted but the headlight washers werent a problem :)
Denis O
Re: MOT Time
Post by Denis O » Tue Dec 01, 2015 8:15 pm
[quote="paulcoles88"]
Brake pipes. Quick scrub with a wire brush and that's sorted.
Headlamp. Not an issue.
Tyres. I guess you knew they were knackered.
Steering. Can't be that bad.
Park brake. 16% is a pass. There's no point them going much beyond that as it's passed already.
Advisory's really piss me off. You have nothing to worry about and congrats on your pass.
05 Mercedes SL350
paulcoles88
Re: MOT Time
Post by paulcoles88 » Fri Dec 04, 2015 12:52 pm
Thank you! :)
It's always a worrying time getting an MOT
TimX5
Re: MOT Time
Post by TimX5 » Fri Dec 04, 2015 10:28 pm
Mine passed last week with flying colours
