Guys...
Doing an exhause manifold change on my Diesel 2004 face lift...
To cover all the bases while she is in pieces.... getting ALL the gaskets etc.
I also have a water coolant leak that is proving elusive to locate..
So.. while everything is in bits, I wanted to swap out the coolant pipe that inputs the block under the exhaust manifold.
What is its technical name, so i can find one on flea-bay.. a i understand this part is a regular coolant failure point .. esp as my truck has done 155k now ?
Regards to all.
what is it called ?
Re: what is it called ?
any one know what this pipe input part is "properly" called?
Have a look at REAOLOEM and see what BMW call it on the relevant drawing?
