How to: Coding a key to the car, E53 and E46
RenoHuskerDu
Post by RenoHuskerDu » Sat Dec 12, 2015 2:16 pm
I bought this E53 with only one key, its remote function inop.  I assumed it was dead, and not having a spare makes me nervous, so I ordered a new key at BMW in Deutschland. The price was €150 (about £120) which seems fair. In general, everything is cheaper at a German dealer than at a French stealer.
Time to program the new key to the car, eh? I searched this forum and found naught.  Bimmerforum and others have it though.  Here it is just in case anybody else needs it. So the next time somebody searches here they can find this.
It worked like a charm, and as an added bonus, the key that came with our car also coded up just fine. So now I have two fully-functional keys.  Life is good.
PROCEDURE TO FOLLOW:
1. Get into the car. Close all doors.
2. Insert new key into ignition.
3. Turn one click to the right, then turn it back, within 5 seconds.
4. Remove the ignition key and hold it so you can push its buttons.
5. Press unlock button and hold. Don't let go until step 7.
6. Within 10 seconds press and release the lock button three times.
7. Release unlock button.
8. LED flashes slowly for 10 seconds (some models).
9. Central locking system locks and unlocks (some models).
10. Step 8 or 9  indicate correct programming.
11. Repeat the above if step 8 or 9 don't happen or LED keeps flashing.
12. Re-code your other keys quickly now (see below).
NOTE: There is a maximum of 4 programmable keys allowed.
Any other keys will need to be re-coded too now (but they will still start the car!)
Perform programming of each subsequent key within 30 seconds.
See https://www.bmwgm5.com/Key_Recode.htm for a scan of the owner manual page on this.
Entwicklung34
Re: How to: Coding a key to the car, E53 and E46
Post by Entwicklung34 » Fri Dec 18, 2015 6:59 pm
This worked for me when I bought my x5 as only one key was operational... However I didn't do step 4 (remove from ignition), but if it works it would be easier than the way I did it!
