auto window descend...
X5-D-Sport
Post by X5-D-Sport » Fri Jan 08, 2016 1:24 pm
Had my battery on & off a few times...
and now, all the windows except the drivers window will lower all the way with a single button push...
for some reason the drivers window now needs the button held to get the window all the way up or down !!
Is there a sequence to correct this ?? O:-)
jonsteele
Re: auto window descend...
Post by jonsteele » Fri Jan 08, 2016 2:12 pm
Most cars I've had required the button to be held down for a number of seconds once the window had completed its travel. It's usually 20, but I'd try 60 to be sure.
Our Discovery used to do this regularly, and the above sorted it each time. If it doesn't, try doing the same after closing.
Sent from the dark side by the power of the force!!
X5-D-Sport
Post by X5-D-Sport » Fri Jan 08, 2016 2:59 pm
cure worked - got it - thanks
jonsteele
Post by jonsteele » Fri Jan 08, 2016 3:30 pm
Glad to be of help.
