I have the old bluetooth connection on my 54 plate X5 i can connect my phone a galaxy note 4 but i cannt ring anyone it just cuts out anyone help ?
also if I go for a upgrade can i still use my steering wheel controls ??
Re: bluetooth connection
I have a note 4 in my 54 plate and it does exactly the same thing.
The E53 has been through about a dozen different bluetooth modules - my note 2 was the last thing that paired properly in my car!
Curr. - Silverstone II F85
Prev. - E70 4.0D M Sport
so looks like a upgrade then
Yeah I gave up trying to source a new (er) bluetooth module. They seem quite expensive for something that I wasn't 100% sure would fix the problem.
I was going to replace the entire head unit with one of these Android units, but I've decided to upgrade the car instead! O:-)
#manmaths
#manmaths
- Steamyrotter
You can upgrade the ULF module.
There are a few on E-bay, but ensure you get a later one than yours....
Sounds obvious, but sometimes the part numbers are not consistent
They did a Gen13 module which, although the most expensive, is the latest one they did to fit.
Should be a simple plug and play job, then re-pair the phone.
As it is the same kit then all previous functions will work (Steering wheel controls etc)
thanks ill give that a go
deep joy :0
deep joy :0
