Replacing handbrake lever
samcoombes
Post by samcoombes » Mon Apr 11, 2016 10:53 am
Hi Guys
So my indy tells me the handbrake lever is worn and needs replacing. I'm hoping to find a used one, but wondered if anyone can give any tips for replacement? I know the centre console has to come out - how easy are the actual cables to remove and replace (one of these has snapped too!)
The Indy wants £560 for the job all in (including a new handle) so i'm looking to DIY it.
Re: Replacing handbrake lever
Post by X5Sport » Mon Apr 11, 2016 5:06 pm
Don't bother with a used one!  Get the part number off Realoem and go hunting for options.
There are a couple of folks on here who have changed them in the past.
samcoombes
Post by samcoombes » Tue Apr 12, 2016 11:19 am
Using the part number on OEM a new lever is nearly £200 from BMW  :blink:
If anyone can offer some advice, on the cables in particular, that'd be grand  ;)
fenj66
Post by fenj66 » Wed Apr 13, 2016 6:37 am
i dont know about replacing cables, but regarding the handbrake lever itself, is it the quadrant thats the problem, i.e. the teeth on the ratchet? if so, if you do get it out of the car, you could get it on a workbench and hacksaw the tooth profile back again. i did it but managed to do it roughly, in situ.
samcoombes
Post by samcoombes » Thu Apr 14, 2016 12:23 pm
Thanks for that - I did consider it, yeah maybe worth a go to avoid a load of hassle!  :D
Steamyrotter
Post by Steamyrotter » Thu Apr 14, 2016 1:05 pm
Refurbed mine too
Finaly got it out and then filed the teeth back in it.
First time in ages that it actually held it in place!!!
samcoombes
Post by samcoombes » Thu Apr 14, 2016 1:15 pm
Did you remove the seat, centre console etc to get it out? Might it be possible in situ with the sides of the centre console removed?
Sanj
Post by Sanj » Thu Apr 14, 2016 1:30 pm
[quote="samcoombes"]
Very tight in there doing it that way. The centre console is a pain to remove but will make access 10 times easier...
samcoombes
Post by samcoombes » Thu Apr 14, 2016 4:35 pm
Thanks - ok.
Any tips on replacing the cables?
Pete
Post by Pete » Thu Apr 14, 2016 6:25 pm
I had a new mechanism fitted for £130. Get a new Indy.
Whereabouts are you?
Steamyrotter
Post by Steamyrotter » Thu Apr 14, 2016 11:39 pm
I took the side panels off the centre console, but left the console in.
Was quite a pain getting the handbrake lever out, but doable.
In fact getting it back in was worse!!!
Post by X5Sport » Fri Apr 15, 2016 4:06 pm
[quote="Steamyrotter"]
Take your gearbox out again next time.... >:D
samcoombes
Post by samcoombes » Fri Apr 15, 2016 4:54 pm
I'm in Dorset.
£120 fitted? The part is more than that even with a good discount....?
Steamyrotter
Post by Steamyrotter » Fri Apr 15, 2016 5:01 pm
Now I CAN manage that alright.....
Huxsta
Post by Huxsta » Fri Apr 15, 2016 5:39 pm
I refurbished mine in situ with a dremel !! Not ideal but worked on every tooth.
