run flat and non runflat on same axle
hi all, i just wanted some opinions on mixing a run flat tyre with a non run flat on the rear. ive had a non repairable puncture so need a temporary part worn tyre as i want to replace them all eventually at the same time. and have been offered a cheap runflat, which would tide me over as it has the same tread depth as rest of the car.
Re: run flat and non runflat on same axle
Don't do it , you should never mix them as the run flat tyre has a thicker rim so won't move as much under load I e in a corner , so the handling will be dangerous ! Best changing an axle at the time . Other thing to note is the tyre sizes mainly need to be within 1-2 MM of each other so don't stick a new 8 MM on with a 3 MM one as on the X3 the transmission can fail leaving you with a 4K bill .
100% right
Definitely don't do it!!!
What size do you need? I have some tyres and alloys in the garage that I need to move on.
Don't. Simples!
Beginning to look like the run flat is a bad idea!! I need one 285/45/19 with 4mm tread to match the rest. Cheers
[quote="fenj66"]
I would ring around a few part worn tyre places if I was you.
I'm sure some may say. " you don't know the history of part worn tyres " but we don't know the history of all 4 tyres we get on our used cars that we buy either.
[quote="fenj66"]
I'll have a look in the garage tomorrow. There is a set of 19" wheels in there but I'm unsure of the brand and tread.
[quote="fenj66"]
Why not stump up for two new tyres and keep the good one for when (not if) you get another non repairable puncture in the future?
I undestand the increased cost, but it means you only need to buy 2 more for the other axle in a months time (spreading the cost effectively)
