Grinding and bumping at low speeds
30boz
Post by 30boz » Tue Dec 27, 2016 11:29 pm
Hello. I've just bought a 2005. X5 4.4 v8 auto. With 162k miles.
I've noticed a 'metal on metal' sound at around 15mph.
It does it in 1st,2nd, and 3rd gears. The auto box won't let me select 4th at the speed the noise happens but. Suspect it's a speed related issue.
It makes a lot of noise then some 'bumping' then sorts itself out and everything is how it should be.
I was wondering if it was clutch plates? It's had a new transfer box recently by the looks of things.
Your thoughts are appreciated
Re: Grinding and bumping at low speeds
Post by X5Sport » Wed Dec 28, 2016 8:24 pm
Get a gearbox code read done (BMW Dealership or Specialist with Autologic system) as that will at least give you some indication as to where to look next.
It could be anything in the transmission line and they often do not bring up warning lights but do record into the fault log.
30boz
Post by 30boz » Wed Dec 28, 2016 9:14 pm
I did a diagnostic and it revealed nothing :(
Post by X5Sport » Thu Dec 29, 2016 9:03 am
Helpful!  Could be the transfer box, gearbox or a diff.  Might even be a CVJ, propshaft bearing or wheel bearing (last one less likely)
Just a thought though, what tyres are fitted?  Are they the correct sizes (check the label in the Driver's B-pillar) and do they have roughly the same tread depth all round?
A while back someone on here reported something similar and I think found the wrong tyre sizes/ratings or something similar fitted.  Changed them and the noise went away.  It may not be relevant for your car, but worth checking anyway.
Steamyrotter
Post by Steamyrotter » Thu Dec 29, 2016 11:11 am
Are you sure it's not brake related?
My hand brake used to make a fair bit of iffy noises.
Don't recommend my method of stopping it though!
(Or more to the point the method forced upon me!!)
30boz
Post by 30boz » Thu Dec 29, 2016 10:09 pm
Thanks all. Off to the local BMW specialist after ny then. I'll let you know the damage!
Nat
Post by Nat » Wed Jan 04, 2017 7:37 pm
Hi,
Dont' laugh at me but there are many heat shields under there. Could be one is worked lose or as you have recently had work done its not been put back properly and is rubbing on a shaft, prop etc etc. It could be that simples. I mention it because I have that tee shirt too after having a new gearbox fitted by a main dealer ...!!
Regards,
Nat.
30boz
Post by 30boz » Fri Jan 06, 2017 1:28 pm
The garage says thereshe nothing wrong. Checked everything prop shafts half shafts cv joints suspension etc. Theyve put it down to the wheels not being standard but they're only 19" I can't believe the originals are smaller?
Post by X5Sport » Fri Jan 06, 2017 5:32 pm
17" available in the base model, 19" staggered set is the standard on the Sport models....unless you have non-BMW 19" wheels?
Post by Horizon » Fri Jan 06, 2017 6:59 pm
[quote="30boz"]
They may mean that the profiles are incorrect, causing transmission wind up, that will cause your symptoms
