Rear suspension
lewiehigh91
Rear suspension
Post by lewiehigh91 » Fri Dec 30, 2016 9:06 am
Hey, I have a creak from the back suspension, and I want to fit this to hopefully cure it, and freshen up the back end. How hard is it all to fit? And do I need a special tool?
EBay item number 112050977054
ianst0028
Re: Rear suspension
Post by ianst0028 » Fri Dec 30, 2016 9:19 am
constant creak/squeak on the back is usually the rear ball joint (its a rose bush but bmw call it a ball joint)
fairly easy to do but you need the right tool to remove/fit the joint
make sure you release the air suspension pressure before you do it or it becomes a very difficult job and things will not go back together easily
X5 e53 3.0 2002 with LPG
lewiehigh91
Re: Rear suspension
Post by lewiehigh91 » Fri Dec 30, 2016 9:30 am
Is it possible to do without the tool?
ianst0028
Re: Rear suspension
Post by ianst0028 » Fri Dec 30, 2016 9:42 am
i tried with the wrong tool and i failed .... so in my opinion no
but i've read of people making tools up to do the job
btw if you replace all the components you'll need to get 4 wheel tracking done
lewiehigh91
Re: Rear suspension
Post by lewiehigh91 » Fri Dec 30, 2016 12:42 pm
Hmmmm....may have a look and see if I can Jimmy it out someway without. Don't like spending money if I don't have to lol :))
ianst0028
Re: Rear suspension
Post by ianst0028 » Fri Dec 30, 2016 2:17 pm
LOLOLOL yeah the proper bush tool is expensive
Re: Rear suspension
Post by henrym3 » Fri Dec 30, 2016 5:25 pm
I did mine recently, looked, thought, yea I can knock that out, take Ian's advice, you won't. Luckily I have a very friendly indie and hired the tool for £10. Money well spent. Just as difficult to put the new one in, needs that same tool.
lewiehigh91
Re: Rear suspension
Post by lewiehigh91 » Sat Dec 31, 2016 7:35 am
Seen them on eBay for 50 quid, will they work?
Re: Rear suspension
Post by henrym3 » Sat Dec 31, 2016 2:33 pm
252378061561 this one is exactly what I used. ebay
Re: Rear suspension
Post by Greydog » Sun Jan 01, 2017 8:59 am
I made up my own from some scrap bits cadged from a local engineering works it did the job fine. As has been said you won't manage without a tool. If you were doing lots then invest in the professional tool. Hopefully once will be enough.
Moments
Re: Rear suspension
Post by Moments » Mon Jan 02, 2017 9:48 am
Definitely get the tool or have one made based on a balljoint that you buy. The critical area is where the wheel carrier gets really close to the top of the balljoint - the tool must have a notch or flat so it seats correctly.
I used some penetrating oil, but even then after eleven years the tool needed a lot of force. Get a small brass rotary brush to clean the corrosion from the inside of the wheel carrier too.
