55 plate e53
Maverick7
55 plate e53
Post by Maverick7 » Wed Jan 25, 2017 5:39 pm
Morning all!!! I've just bought a 55 plate x5 e53. My indicator light on the dash flashes like mad when turning right. I've changed the bulb as I thought it was that. Nope. Swapped left to right. Works fine on left...... so not bulb holder. Anyone had similar or is this a common fault with the light unit??? Tganks
Re: 55 plate e53
Post by X5Sport » Wed Jan 25, 2017 6:21 pm
Checked all 3 bulbs?  Front/Rear/Side Repeater?
Could be bad wiring a little further back if the holder is OK.
Maverick7
Re: 55 plate e53
Post by Maverick7 » Wed Jan 25, 2017 6:24 pm
Yes. Front and repeater working fine. That's what had me baffled. Just thought.... bulb.
Re: 55 plate e53
Post by Horizon » Wed Jan 25, 2017 6:29 pm
I was going to mention try swapping all the bulbs from one side to the other, maybe one is an LED, so not getting enough resistance on one side, but enough to not trigger the bulb out warning ( or that's been turned off )
grumpywurzel
Re: 55 plate e53
Post by grumpywurzel » Wed Jan 25, 2017 6:52 pm
So is it just the indicator on the dash going nuts or are the side lights flashing at the same speed?
2005 X5 3.0d Sport
Maverick7
Re: 55 plate e53
Post by Maverick7 » Wed Jan 25, 2017 8:51 pm
No indication from the actual unit on the rear right. Left all working fine. Dash light flashing ok when I indicate left. Just going nuts when I indicate right!!!
Re: 55 plate e53
Post by X5Sport » Wed Jan 25, 2017 9:10 pm
Rear light units are known to go bad due to water ingress.  You may have to remove it to have a careful look at the wiring and connector at that end.  It could be in the plug that connects the car to the light unit itself.
Maverick7
Re: 55 plate e53
Post by Maverick7 » Thu Jan 26, 2017 7:39 am
Thanks all. I'll remove it and keep you informed
Maverick7
Re: 55 plate e53
Post by Maverick7 » Fri Jan 27, 2017 5:13 pm
Removed today. All connections cleaned with wire wool. ...... working fine!
Re: 55 plate e53
Post by X5Sport » Fri Jan 27, 2017 6:52 pm
Result  :D
