BG244
Beamer
BG244
Post by Beamer » Tue Feb 07, 2017 3:25 am
Hi guys, I have a question. Has anyone heard of BG244 ? I have just heard a friend who has used it. Now I would like to know what others think ?
Smeeagain
Re: BG244
Post by Smeeagain » Tue Feb 07, 2017 6:39 am
Yes ive used it. BG make a range of products. There is a fuel cleaner, a diesel version and a petrol version, to clean up injectors etc. There is an engine oil flush (search for my post titled Have you flushed) and an oil additive which as far as I can tell adds a teflon like coating. My car, a 2004 E53 3.0D sport, was running a little lumpy when cold. The diagnosis was sticky fuel injectors. On the advice of a mechanic friend, I tried some BG fuel cleaner. At £20 or so there was nothing to lose if it didnt work and a lot to gain. It seemed to do the trick. The car idles more smoothly and seems more responsive, although I am aware these products contain cetane enhancers to increase the burn temperature to burn off all the crap, so the perceived power increase and responsiveness may come from that. Im told you should chuck it in the tank once every quarter or so. Ive only done it once so far but plan to do it again.
What was your friend's verdict?
Smee
Beamer
Re: BG244
Post by Beamer » Tue Feb 07, 2017 8:28 pm
Thanks for the reply, he seems to think its great. If I can source any here in Northern Ireland I might give it a tr.
Smeeagain
Re: BG244
Post by Smeeagain » Wed Feb 08, 2017 12:20 am
you can get it on Amazon. Im guessing they have Amazon in deepest darkest Northern Ireland ......
Beamer
Re: BG244
Post by Beamer » Wed Feb 08, 2017 5:18 am
I would not be too sure about that. We have running water no don't you know.  :D :P
Colin
Re: BG244
Post by Colin » Wed Feb 08, 2017 10:05 am
And there's talk of electricity coming  lol
05 , 30d Le Mans Blue Sport
Colin
Re: BG244
Post by Colin » Wed Feb 08, 2017 10:14 am
I have used Millers oils  Diesel power eco max additive  50ml per fill  , says 100ml per fill for extra boost ,
have also used dealers additive £10 per tin per fill
Smeeagain
Re: BG244
Post by Smeeagain » Wed Feb 08, 2017 10:38 am
I guess the OP has to decide why he wants t use either product. If more power then the power stops when there is no additive in the tank, so you have to keep using it. The 'power' comes from increasing the octane and burn temp and Im not convinced that is ok for long term use. Cheaper and better probably to get Jason to do a remap
OR
use it for the cleaning properties which i did and it seemed to work.
Smee
Colin
Re: BG244
Post by Colin » Wed Feb 08, 2017 12:34 pm
I only used it for a cleanout of the system every 3 or 4 month , have to be careful where we get our diesel here !!
As for remap have it done a year or more now  had a chat with Jason and he has a good friend over here that he put me in touch with  TorqueTronix Kells N Ireland
Beamer
Re: BG244
Post by Beamer » Wed Feb 08, 2017 9:40 pm
Its more as Colin says to clean the system out. My X5 does not get driven hard maybe I should once in a while.
