Banging noise under acceleration
giddyal
Post by giddyal » Tue Feb 21, 2017 11:55 pm
Gentlemen,
I have a 2002 3.0i X5 and under acceleration there is a banging noise which I think is coming from the back of the vehicle. I suspect that it is the transfer box chain but before I commence the tricky job of replacement can anyone confirm that this is the likely cause.
By starting off very gently I can avoid the noise but it needs to be fixed.
Thank you in anticipation.
Giddyal
Re: Banging noise under acceleration
Post by X5Sport » Wed Feb 22, 2017 6:05 pm
Transfer box is beside you rather than at the rear.  Could be a suspension bushing issue - known to wear out at that age.
An alternatives could prop shaft support bearing, exhaust, or even rear diff.  I'm assuming nothing is loose below the boot floor?  Stranger things have happened - like a loose battery.
kkx5
Post by kkx5 » Wed Feb 22, 2017 7:44 pm
2002 x5...no xdrive...could be: front drive shaft splines worn??
graemeX5
Post by graemeX5 » Wed Feb 22, 2017 8:29 pm
I think I would go for the easy diy one of checking the exhaust rubbers first because athe exhaust can knock if worn, and as it would move when under acceleration.
Its not too costly to fix remember to check both rear boxes and also centre box as that has 3 hangers according to realoem
Graeme
Upex
Post by Upex » Sat Apr 15, 2017 6:36 am
I had the same with a former car, was the big rubber circular thing that connects drive safe half's (like The crush drive on a bike), had a little bit or movement and knocked under hard acc. Slowly it didn't do it. 4 or 6 bolts later, sorted.
Not sure if pertinent to your motor though  :'(
Steamyrotter
Post by Steamyrotter » Wed Apr 26, 2017 1:27 pm
Firstly no one noticed its an E53 in the F15 section???  O:-)
Secondly I would suggest the rear sub-frame bushes....
