downgrade MKIV satnav
neilbm
Post by neilbm » Mon Mar 13, 2017 6:52 pm
does anyone know if it's safe to downgrade the satnav?
I've a "High" MKIV system in the trunk and have got version 4-1/01 displayed on the computer, which I believe is v32.1 customized version
I have got hold of a copy of V32 software but am wondering if it's safe to downgrade to V32 from what I have? anyone?
neilbm
Re: downgrade MKIV satnav
Post by neilbm » Tue Mar 14, 2017 9:13 pm
just went for it in the end, crossed fingers and all that ... all fine  8)
Post by X5Sport » Tue Mar 14, 2017 9:27 pm
Glad it went OK.  The only real worry is if the firmware disc is a poor quality copy (unless you have sourced an OEM one) as these drives can be fussy about the discs they are fed.  Rarely, but it does happen, the drive 'bricks' and getting it to recover can be painful.
neilbm
Post by neilbm » Wed Mar 15, 2017 8:13 pm
ta
only problem i need to sort now is the car has turned french on me unless i have the speed camera alerts on. i guess that's because somewhere the car is programmed to use french?? how do i change it? cheers
Post by X5Sport » Wed Mar 15, 2017 8:54 pm
Copy discs have this issue.  Genuine discs don't have speed cameras on them, or didn't have.  Have you checked the software version number to make sure it is correct?
neilbm
Post by neilbm » Wed Mar 15, 2017 9:23 pm
pretty sure this is correct?
Post by Horizon » Wed Mar 15, 2017 9:50 pm
Get a genuine disc off eBay. The discussion on copy discs is not allowed on this site.
CondorX5
Post by CondorX5 » Thu Mar 16, 2017 7:29 am
That is non OEM software - as said the BMW system disc does not have camera alerts. And the French language change is a well known issue.
Get a proper disc - non OEM software cannot be discussed on here, its against forum rules.
X5 2005 Le Mans Blue 4.8is
neilbm
Post by neilbm » Fri Mar 17, 2017 7:12 am
oops ok i wasn't aware it was non OEM. so what version would be OEM? or should i say what numbers should be visible in the config menu if genuine software loaded?
i wasn't attempting to chat about copy discs, just to understand who i fix this stuff for me, honest guv
Post by X5Sport » Fri Mar 17, 2017 4:36 pm
The numbers match the last official version but the disc you have may have added new voice/function files from a 'modified' batch file.  Whether you can get rid of that bit once installed is unknown, but try a genuine map data disc and see if it disappears again.
If you are getting French with Speed Cameras off then it's a modded disc.  Something to do with the way the voice files have been coded.
Your BMW Dealer may know how to factory reset the firmware and then bring it up to Version 32....the last official release.
