Wheel wobble on cornering
Post by Alan Gunn » Mon Apr 10, 2017 11:13 am
Any idea why i sometimes get a wheel wobble when going round a bend.
Re: Wheel wobble on cornering
Post by X5Sport » Mon Apr 10, 2017 6:27 pm
Have you checked wheel bolt torque, wheel bearing play, CVJ movement, warped disc (suggesting this in case it is a pad rubbing against it although I would expect vibration under braking), worn suspension bushes and showing under 'load' due to cornering?
Post by Alan Gunn » Mon Apr 10, 2017 6:35 pm
Thanks for the reply.
All brakes new.
No clicking or any sign of the cv joints failing.
Not sure about the wheel nut's torque will check in the morning.
As for the rest the garage will have to look at.
Post by henrym3 » Mon Apr 10, 2017 7:46 pm
I would add to that a knackered shock absorber
