can someone assist on the fault code i have attached on photo. Not sure if this means the glow pin is faulty or not, i did take it out a while ago and out 12v to it , it lit up red so i presumed it was fine but im no expert.
Is there anything else that may be causing the problem such as this pcb that seems to cause trouble maybe not supplying the voltage it needs. Also, should the heater actually fire up as if it were working as normal if turned on in the INPA programme where it says turn on heater.
