Double glazed vs single
x5e53
Post by x5e53 » Thu Jul 06, 2017 5:48 am
Hi,
Will double glazed window panes (1 per door) fit into the slots/runners for a e53 designed for single paned windows? I.e. is it a straight swap?
On the 7 series, you need to install different trim pieces as the glass was considerably thicker.
graemeX5
Re: Double glazed vs single
Post by graemeX5 » Thu Jul 06, 2017 7:51 am
I don't know but would expect it to be different .
To confirm this it's worth checking www.realoem.com and from that you should see if there are different part numbers for the trim.
Graeme
BSJ_Denmark
Post by BSJ_Denmark » Thu Jul 06, 2017 9:47 am
You will need new slots and panels - NOT a plug'n play thing to do !
Best regards
Brian S Jensen
E70 X5, xDrive 40d M-Sport Individual, 2012
E39 530d Touring Steptronic, 2002
E61 530i Touring Steptronic, 2005
RickUK
Post by RickUK » Thu Jul 06, 2017 10:52 am
If the windows are a easy change over,would the existing motors be able too handle additional weight of moving the windows up and down ?? On the 7 series i would think that they must have slightly bigger motors.
Also i am trying to rack my brain what advantage are you looking at gaining by the upgrade,as i cannot work it out.
2006 '56 BMW X5 D M SPORT LE-MANS EDITION
http://www.hideones.info
Smeeagain
Post by Smeeagain » Thu Jul 06, 2017 4:07 pm
HE feels the cold. Or he wants a bulletproof inner panel ........  :))
Smee  :)
x5e53
Post by x5e53 » Fri Jul 07, 2017 10:08 am
[quote="Smeeagain"]
Smee  :)
Erm no.
I need to replace 1 glass pane as its cracked.
Local scrapy has all 4 for 30quid. But they are double glazed.
I wanted to see if it would be a straight swap as its a cheap price.
Smeeagain
Post by Smeeagain » Fri Jul 07, 2017 8:24 pm
So just buy all the bits tbat go with it to make it a straight swap. Still begs the question why the one in the scrappy is double glazed. Weird spec and I dont recall it being an optional extra, but I might be wrong. Believe it or not it has been known to happen
Post by X5Sport » Fri Jul 07, 2017 9:26 pm
Double glazing was an option when I was speccing mine in 2004.  I really could not see what real purpose it would serve unless it also came with added sound insulation and 10" of fibreglass wrap!  It wasn't cheap either!
