Cold start
Silverfox58
Cold start
Post by Silverfox58 » Thu Nov 09, 2017 6:29 pm
Hi all I think it's time to change the glow plugs or relay, as in the last couple  of days as it's got cold it starts ok but runs a little  lumpy  for a second or two, I have put the code reader  on and it says I have fault on all of them,  now should I change the relay and  try that first or just do the lot .
X5 30d
marinaman
Re: Cold start
Post by marinaman » Thu Nov 09, 2017 8:02 pm
Ha  :D    just what happend to me,  i got the control box 1st  fitted it  bit of a sod  but  then    :'(  just the same,
bought 6 Bosch glows from Amazon,  looked on here for job tips. Seemed to be a lot saying the farthest one was a pig to get at,  but  all you have to do is remove the panels around the bulkhead and lift out the pollen filter box and you have easy access to all 6,  this also makes the access to the control unit a lot easier.
watch out at the every far right end of the rocker cover,  theres a hidden bolt for a sensor,  get a little ladies mirror and it makes jobs easier to see than working blind.  and dont drop the bolts. :))
Was recommended to spray with plusgas for a while  but mine came out very easy,  burnt and blackend every one of them.
I say set aside a day when doing nothing as its one of the big jobs you need time in case you have problems.
Re: Cold start
Post by X5Sport » Thu Nov 09, 2017 8:12 pm
Do the lot and the Control Box.  A number of people have changed the plugs and had the controller go almost immediately after.
The manufacturer you want is Beru  :)
Silverfox58
Re: Cold start
Post by Silverfox58 » Thu Nov 09, 2017 9:02 pm
Ok thanks  for the heads up will have to sort a day to do it all then.
Thanks Paul
X5 30d
Silverfox58
Re: Cold start
Post by Silverfox58 » Thu Nov 09, 2017 9:05 pm
So my next question  is whats the best ones to get
X5 30d
Re: Cold start
Post by Alan Gunn » Fri Nov 10, 2017 6:38 am
[quote="Silverfox58"]
"The manufacturer you want is Beru "
Silverfox58
Re: Cold start
Post by Silverfox58 » Fri Nov 10, 2017 7:41 am
X5 30d
Smeeagain
Re: Cold start
Post by Smeeagain » Fri Nov 10, 2017 3:15 pm
:)) :)) :)) :)) :P :-[ :'(
