Scanner 1.4.0. software
kanewesley
Post by kanewesley » Sat Dec 30, 2017 10:26 am
Hi, don't know if this is allowed on here but ......
I dont have a scanner 1.4.0 but have another software suite which has SSS PROGMAN, INPA, EDIABAS, WINKFP, TOOLSET32, DIS / GTI, NAVCODER.
I'm STILL trying to switch in my AUX. HEATING as an option on my X5 2006 d facelift.
Nothing in the above software suite seems to allow this,....
The software will get the car to the moon and back but won't switch Aux. Heating as an option on my display.
I have read I need Scanner 1.4.0 to do the trick.
My question is can someone talk me through how to do it via an idiot sheet for the software suite I have...alternatively, if I download the 1.4.0. software from somewhere (though I don't know where) can I use my existing interface or do I need one specific to the 1.4.0. software?
Thank You
Re: Scanner 1.4.0. software
Post by X5Sport » Sat Dec 30, 2017 12:15 pm
Just a thought, but what else (apart from allowing remote operation) does the module you need in the boot do?  You can use Telestart 70/80/90 units for remote control but I don’t know if those modules are also needed to enable the Aux Heating mode?  The wiring is all in place so the module is just plug and play.
kanewesley
Post by kanewesley » Sat Dec 30, 2017 1:19 pm
wǒ bù xǐhuan ròu,wǒ xǐhuan chī yú......不喜欢肉,我喜欢吃鱼。??????
Thanks very much for your reply but thats a bit over my head Bud ?
MIght as well be written in chinese ?
Post by X5Sport » Sat Dec 30, 2017 4:45 pm
Aux Heating came with a remote control and an additional (plug-in) module in the boot.  It’s a Webasto Telestart.  You might need it.
kanewesley
Post by kanewesley » Sat Dec 30, 2017 6:48 pm
Thanks BUd,
Where might I get one?.....and if the aux. heating is enabled....can't the timer in the cabin be set like aux. ventillation?
Post by X5Sport » Sat Dec 30, 2017 9:43 pm
That generation of Telestart is getting old now, but was used in all sorts of cars.  Have a look for Telestart T60, T70, T80 on Line.  They are all the same basically.  Not cheap though and eBay may be your best option.
Can’t help with the timer part as I never had the option on my old E53 - sorry.
marinaman
Post by marinaman » Sat Dec 30, 2017 11:12 pm
If heater is faulty then the telestart wont make it work, apply 12v to pin 1 on the heater for 3 mins and it should go through starting up cycle
if it wont start. like mine then somethings up.
if aux heat is enabled as i did mine you can set the start up time for the morning to warm car up but if heater wont work with 12v to pin 1 then the timer wont do anything either.
kanewesley
Post by kanewesley » Sun Dec 31, 2017 10:51 am
I'll be making me way to Brid soon bud if thats ok  :)
marinaman
Post by marinaman » Sun Dec 31, 2017 3:28 pm
no problem  just let me know i can easily turn it on for you
kanewesley
Post by kanewesley » Thu Jan 04, 2018 3:55 am
Thanks !
