Tank Ventilation Valve
jason1872
Post by jason1872 » Tue Mar 13, 2018 4:09 pm
Hello guys i've just replaced the ccv in my 02 3.0i i now have error 68 Tank Ventilation Valve error with the EML on i've replaced the valve but still get the error,i have found a plastic pipe under the manifold next to the valve that doesn't seem to attach to anything this pipe has a bend in it and points inwards towards the manifold,on checking the plug that goes onto the valve the plug has only 1 female pin and the valve has 2 males pins,any help would be much appreciated.
Re: Tank Ventilation Valve
Post by henrym3 » Wed Mar 14, 2018 4:05 pm
My understanding of the vent valve is there are two pipes one in from the tank one out to throttle body and ecu cycles the valve. Mine has a 2 pin plug 2 male pins on the valve and 2 female on the lead/plug
jason1872
Post by jason1872 » Wed Mar 14, 2018 4:15 pm
Thanks for the info,turns out i had managed to miss a connector and was lying behind the loom but i now have a spare connector with 1 female pin inside lying spare any idea where it should be?
jason1872
Post by jason1872 » Thu Mar 15, 2018 4:27 pm
All connected now,missed the oil pressure sensor.
