Sticky calliper, DIY fixes?
I’m booked in with my indie next week to get new front pads fitted to e70 x5
I have a sticky calliper and that the alloy wheel gets very hot on a run
I’m hoping it’s fixable, clean, lube job; but without buying a new calliper; are there any parts I should get just in case, as I’m supplying my own pads and sensor?
Hoping the discs aren’t warped, but how does one tell?
I’ve ran my finger over it and the face isn’t as smooth as the other side
Re: Sticky calliper, DIY fixes?
I have had 2 done on my car.
I buy the parts and my m8 with a garage fit's them.
I buy a piston kit everything you need from this site and delivery is fast.
http://biggred.co.uk
They also sell on ebay user name is biggred4u
I was looking on eBay but many different kits
Which ones did you go for?
Any specific links would help?
[quote="celica"]
Go on real OEM and put your last 7 digits in and see what part no's your callipers are, then type that number into google and that will give you alternative part numbers.
Thanks, I’m aware of checking oem parts
But the link above has kits of differing things
This is the link for the ones that i got for my 2002 x5 3.0d
On the biggred site just put your reg number in and then click the tab for the kit you want.
If you want to pm me your reg number i will find the parts for you.(don't take that the wrong way i just want to help lol)
https://www.ebay.co.uk/itm/FRONT-Brake- ... SwExlaYcRj
This might be the set you need but double check.
https://www.ebay.co.uk/itm/FRONT-L-R-Br ... Swx-9WxMqW
Thanks for above help
Have ordered the calliper and piston repair kit, front axle
£40 all in. Hope they turn up by the 12th as stated as backup to have when I take my car to my indie on Friday
I think you will get them by Wednesday.
Always had quick delivery from them.(well if you got them from where i think)
This is the one but I think this is the single piston whilst I may have twin?
FRONT L & R Brake Caliper Repair Kit +Pistons for BMW X5 E70 & X6 E71 (BRKP57) https://rover.ebay.com/rover/0/0/0?mpre ... 2878409620
The seller is updating the contents for a twin piston
Which I assume is correct for the 3.0sd
You need to check on Realoem in case you have single piston units.
Strangely enough I have got an issue with my front right caliper on the X6 this morning. It definitely wasn’t happy after a 30-mike drive and the wheel was warm.
Coming back this evening though it is fine and all wheels are cool to the touch. The calipers on mine are definitely single piston ‘sliding’ assemblies.
The car isn’t getting much use and I suspect salt corrosion is the cause of these symptoms. Once it stops weeing down outside for more than 5 minutes I’ll have the wheel off and a good look to see if I need to replace much.
The original item was sent out so have ordered a twin pisto kit too
Will just send one kit back
Hoping mechanic is able to fix
update
mine are twin piston
kit wasn't needed at first. one piston was stuck wide open, but the mechanic thought it would move back freely and wasn't corroded it probably got stuck wide open and should be fine.
new pads fitted as last set were worn to bare metal.
off I went to collect some Pagid discs to fit.
5 miles drive and the wheel is hot and so assume the piston is wide open again.
going back tomorrow for new discs as worn badly and he's going to look at rebuilding the caliper
