Having now fixed the PDC ( yipee)
As a result the bumper is "saggy" under the headlight simply because the clip is not supporting it.
I have sourced the plastic bracket and it looks like its secured by two screws at either end (no problem to get off ) and its then a push fit into two holes on the wing itself with plastic snap fit clips that are moulded onto the bracket itself. This secures then secures the bracket and as a result the bumper can sit flush up to the wing.
I am assuming that once the screws are off you can pry / drill/ lever (i can hear the snap already ) of the bracket ( no doubt the snap fits will break) from the outside and there is no reason why you should need to get behind the wing itself ?
Has anyone ever done this and how easy.
I can get the bumper off easily and given its only the one corner i am sure i can work it, but need to understand if its just as simple as i make it sound. what worries me is i am missing something that i cannot see on the flip side of the inner wing !!
As always any help appreciated - last thing i want is the bumper worse than before i start .....it has been known.....
