Finally ready for the road
hennabm
Post by hennabm » Sat Jun 30, 2018 1:12 pm
Hi all
After much work inside and out, my E53 is now ready for the road.
To summarise the work done I have changed the battery, had the BM54 module repaired and upgraded, change the driver's door handle carrier, seat module on the driver's seat and the tailgate upper switch.
I also bought a new key and had that coded in. When the dealer coded it they noticed it hands' had the air bag recall so I ended up with a new driver's air bag.
Externally I have had th sump gasket changed, all filters, antifreeze, transmission oil and filter, rear brake pipes, NSF CV gaiter and NS engine mounting.
I have also cleaned it inside and out.
Now it needs to prove itself over the next 6 month. If it does then I will buy it some new headlamps and repair the driver's seat bolster.Image[img]
11 3.0d X3
02 3.0l X5
82 323i
90 320i
10 116d
89 240DL
12 Punto 1.4
Re: Finally ready for the road
Post by marti » Sat Jun 30, 2018 6:52 pm
Good work, whats the matter with the headlights??
hennabm
Post by hennabm » Sat Jun 30, 2018 10:54 pm
The plastic looks like it has a sort of lacquer on them around the bottom edge and over the indicator area.
I fancy some angel eyes after market type and keep the White indicator look that it now has.
Any tips?
11 3.0d X3
02 3.0l X5
82 323i
90 320i
10 116d
89 240DL
12 Punto 1.4
Post by henrym3 » Sat Jun 30, 2018 11:10 pm
You could clean up the headlights to get rid of that faded look quite cheaply whilst your waiting on the X to prove it’s self. You can use anything from toothpaste to a dedicated headlight refurb kit from Halfords/eBay or such like.
hennabm
Post by hennabm » Sun Jul 01, 2018 9:26 pm
Hi henry
I tried the toothpaste trick and that didn't have any effect whatsoever.
Maybe I was using the wrong toothpaste :)
Did around 120 miles today and I have to say - it was great. Look forward to a continuing ownership, so long as she behaves.....
11 3.0d X3
02 3.0l X5
82 323i
90 320i
10 116d
89 240DL
12 Punto 1.4
Raj
Post by Raj » Tue Jul 03, 2018 1:36 pm
Certainly was a list of things to get through.
Good job on getting her back to roadworthy condition and it sounds like she's behaving.
I used the meguiars kit for the headlights and it worked a treat.
lezmtaylor
Post by lezmtaylor » Tue Jul 03, 2018 4:57 pm
Hi Raj, welcome back, nice to know some old faces are still around.
Lez
Raj
Post by Raj » Thu Jul 05, 2018 12:30 am
[quote="lezmtaylor"]
Lez
Hi Lez,
Thanks, it’s been quite some time hasn’t it.
Will try and keep on here a little more regularly.
Silverfox58
Post by Silverfox58 » Fri Jul 13, 2018 6:58 pm
Hi ya just a quick question how hard was it doing your rear brake lines at the back as I might  have to the same  on my 5
X5 30d
hennabm
Post by hennabm » Fri Jul 20, 2018 5:45 pm
Hi silverfox
It was easy on a to post ramp. The font t far cover was dropped at the back and I made a join under there.
The ones to t flexis were bought pre formed and fitted unite simple.
What amazed me is that all the nipples came undone quite easily.
Good luck with yours.
11 3.0d X3
02 3.0l X5
82 323i
90 320i
10 116d
89 240DL
12 Punto 1.4
hennabm
Post by hennabm » Fri Jul 20, 2018 5:47 pm
I have to say that this is the first car for many years where I want to go the long way home to just drive it. 8)
11 3.0d X3
02 3.0l X5
82 323i
90 320i
10 116d
89 240DL
12 Punto 1.4
Silverfox58
Post by Silverfox58 » Tue Jul 31, 2018 5:33 pm
Thanks for your reply, unfortunately I will be on my back  :( but haho
X5 30d
