Finally ready for the road
Posted: Sat Jun 30, 2018 1:12 pm
by hennabm
Hi all
After much work inside and out, my E53 is now ready for the road.
To summarise the work done I have changed the battery, had the BM54 module repaired and upgraded, change the driver's door handle carrier, seat module on the driver's seat and the tailgate upper switch.
I also bought a new key and had that coded in. When the dealer coded it they noticed it hands' had the air bag recall so I ended up with a new driver's air bag.
Externally I have had th sump gasket changed, all filters, antifreeze, transmission oil and filter, rear brake pipes, NSF CV gaiter and NS engine mounting.
I have also cleaned it inside and out.
Now it needs to prove itself over the next 6 month. If it does then I will buy it some new headlamps and repair the driver's seat bolster.Image[img]
Re: Finally ready for the road
Posted: Sat Jun 30, 2018 6:52 pm
by marti
Good work, whats the matter with the headlights??
Posted: Sat Jun 30, 2018 10:54 pm
by hennabm
The plastic looks like it has a sort of lacquer on them around the bottom edge and over the indicator area.
I fancy some angel eyes after market type and keep the White indicator look that it now has.
Any tips?
Posted: Sat Jun 30, 2018 11:10 pm
by henrym3
You could clean up the headlights to get rid of that faded look quite cheaply whilst your waiting on the X to prove it’s self. You can use anything from toothpaste to a dedicated headlight refurb kit from Halfords/eBay or such like.
Posted: Sun Jul 01, 2018 9:26 pm
by hennabm
Hi henry
I tried the toothpaste trick and that didn't have any effect whatsoever.
Maybe I was using the wrong toothpaste :)
Did around 120 miles today and I have to say - it was great. Look forward to a continuing ownership, so long as she behaves.....
Posted: Tue Jul 03, 2018 1:36 pm
by Raj
Certainly was a list of things to get through.
Good job on getting her back to roadworthy condition and it sounds like she's behaving.
I used the meguiars kit for the headlights and it worked a treat.
Posted: Tue Jul 03, 2018 4:57 pm
by lezmtaylor
Hi Raj, welcome back, nice to know some old faces are still around.
Posted: Thu Jul 05, 2018 12:30 am
by Raj
[quote="lezmtaylor"]
Hi Lez,
Thanks, it’s been quite some time hasn’t it.
Will try and keep on here a little more regularly.
Posted: Fri Jul 13, 2018 6:58 pm
by Silverfox58
Hi ya just a quick question how hard was it doing your rear brake lines at the back as I might  have to the same  on my 5
Posted: Fri Jul 20, 2018 5:45 pm
by hennabm
Hi silverfox
It was easy on a to post ramp. The font t far cover was dropped at the back and I made a join under there.
The ones to t flexis were bought pre formed and fitted unite simple.
What amazed me is that all the nipples came undone quite easily.
Good luck with yours.
Posted: Fri Jul 20, 2018 5:47 pm
by hennabm
I have to say that this is the first car for many years where I want to go the long way home to just drive it. 8)
Posted: Tue Jul 31, 2018 5:33 pm
by Silverfox58
Thanks for your reply, unfortunately I will be on my back  :( but haho
