Folding mirrors
Silverfox58
Folding mirrors
Post by Silverfox58 » Fri Jul 13, 2018 6:52 pm
Hi all
My mirrors fold in but don't stay there, I have taken the microswitch out and the arm was flat , I've seen on YouTube that it has
A fold in it, can I buy one of them or I will have to try and bend it, what else stops the mirrors from folding back.
X5 30d
Re: Folding mirrors
Post by marti » Fri Jul 13, 2018 6:59 pm
I dont think your problem is the arm, from what you've said if that were the case the motor would be running all the time trying to force the mirror back....which doesn't make sense....are both sides doing it?,,if so...sounds more like a problem with the switch control button...the one you press to operate the mirrors sticking or its give up the ghost...hard to do but try to give it a blast with air from a can or WD40
Silverfox58
Re: Folding mirrors
Post by Silverfox58 » Sat Jul 14, 2018 12:00 pm
Hi all well this is what I need if anyone could point me in the right direction
X5 30d
Re: Folding mirrors
Post by marti » Sat Jul 14, 2018 2:25 pm
Thats a micro switch....bend it to the correct position and a good spray of WD40
Silverfox58
Re: Folding mirrors
Post by Silverfox58 » Sat Jul 14, 2018 2:52 pm
Hi Martin it works it's just trying to bend it right when I don't  know  what it looks like in the first place :))
X5 30d
Re: Folding mirrors
Post by henrym3 » Sat Jul 14, 2018 3:39 pm
The micro switches are the same each side. I know it would be a PITA but if you uncover the other side that will let you see what it should look like
Silverfox58
Re: Folding mirrors
Post by Silverfox58 » Sat Jul 14, 2018 4:27 pm
There both the same , I have found a picture  now So will have a go later.
X5 30d
AW8
Re: Folding mirrors
Post by AW8 » Sun Jul 15, 2018 2:10 pm
Bmw do not stock the switch as a part item. I researched this.....the switches were available but only as bulk order from the supplier.
Prior discussed  on thread links  below albeit nothing useful really evolved re sourcing.
http://xdrivers.co.uk/forum/https://xdr ... ic.php?t=4
http://xdrivers.co.uk/forum/https://xdr ... ic.php?t=8
Its a Burgess V4NCO8
Silverfox58
Re: Folding mirrors
Post by Silverfox58 » Mon Jul 16, 2018 5:38 pm
Hi AW8 yes it is do you have them for sale
X5 30d
AW8
Re: Folding mirrors
Post by AW8 » Mon Jul 16, 2018 6:15 pm
Last post unclear please clarify
Are you saying they are for sale .
If so post/share link or procide more info please.
Silverfox58
Re: Folding mirrors
Post by Silverfox58 » Tue Jul 17, 2018 3:19 pm
Sorry  no I was asking you if you had them  for sale
X5 30d
AW8
Re: Folding mirrors
Post by AW8 » Tue Jul 17, 2018 4:43 pm
Thanks for clarifying your post.
As per my post (7) above...."nothing really evolved re sourcing"
You could always try to make some calls or send emails. The part was available in bulk..It would simply be a case of asking the manufacturer to pass your contact details to one of their wholesaler customers with a request the wholesaler buyer contacts you direct in their capacity as a retailer.
AW8
Re: Folding mirrors
Post by AW8 » Tue Jul 17, 2018 5:16 pm
Just found the following info for you after 30 mins of Google and forum searching (credit to rodgethedodge on xoutpost). The info was posted within last 6 months
"I know this is an old thread but I sourced my switch from RS Components Ltd. I expect they would ship to the US.
SPDT-NO/NC Roller Lever Microswitch, 3 A @ 250 V ac
RS Stock No. 472-8291
Mfr. Part No. V4NSYRUL
Brand Saia-Burgess
They are £5.72 each
£6.86 with VAT for 1 to 49 units + free shipping in the UK
You still have to swap over the lever.
Connect Blue wire to Blue wire in harness and
Red wire to the white/yellow wire in harness
Hope this info helps somebody"
NOTE THAT  AUTHOR STATES YOU STILL HAVE TO SWAP OVER THE LEVER.
.....If he is referring to the spring(s) that bend this remains an unresolved issue. I say this as pics above indicate same issue I had on mine.....the metal lever/spring being distorted out of shape !!!!
Please can I ask that if anyone sources switches &/or spring/levers that they update this thread please .....thank you.
https://uk.rs-online.com/web/generalDis ... contact-us
Oh and good luck :)
Re: Folding mirrors
Post by Alan Gunn » Tue Jul 17, 2018 5:22 pm
Re: Folding mirrors
Post by henrym3 » Wed Jul 18, 2018 4:17 pm
Don’t suppose anyone has a wiring diagram for the folding mirrors. One of mine when pressed for up goes left. My own fault. I could just play around with the pins but if someone has a wiring diagram life would be so much easier.
