Post
by fairzy » Tue Jul 31, 2018 10:07 pm
[quote="snrbrtsn"]
That doesn’t look right
For reference, I have my rear bar located at the rearmost door gap, allbeit some one say I have them set too far apart
In your case, if you remove the rear bar, unscrewing the clamp fully, on the underside, at each end, you’ll find x2 bolt heads that run on elongated holes to allow adjustment, loosen these and offer bars back in rail, ensuring the pad sits flush
If possible nip up the bolts, then remove and tighten refit bars and recheck footplates
Unfortunately, I can’t provide pictures sorries
Note : I also tighten my bars in stages, two turns alternate sides holding the clamp under the rim of the bar until torqued circa 7nm with the fitting tool
Thank you for that, I will check tomorrow. I’m now doubting if I’ve even got the right rail version - I need flush. Can you tell from the pics? Unfortunately all of the stickers have come off.
