Seems like an odd question but while looking at RealOEM at the differences between the exhaust manifold of the M57 vs the M57N, I noticed that the older M57 engine has a cast manifold (#1), fitted with a heat shield #6).
I was wondering if it is important to add this shield to a cast manifold (such as that from X8R) when replacing the manifold on an M57N facelift car and if anyone has done this? The OEM M57N exhaust manifold seems to be double skinned and is likely cooler on the outside...
I can't see this shield protecting much, except for maybe the turbo, which has exhaust gases running through it anyway (well, the turbine does...). Or perhaps the compressor outlet pipe is closer to the manifold on the older car?
You can see the heat shield in the second image (behind the number 2) on this page...
https://workshop-manuals.com/bmw/x_series_e53/x5_3.0d_m57_offrd/2_repair_instructions/11__engine_(m57)/62__exhaust_manifold/1_ra__removing_and_installing_or_replacing_exhaust_turbocharger_(m57)/page_591/
Just curious - not worried. ::)
