uphill judders
Loperamide
uphill judders
Post by Loperamide » Sun Dec 02, 2018 1:31 am
After my car has warmed up it occasionally judders while going uphill.
Also the rev counters bounces around about the 40-50mph speed.
What could be causing this?
2003 4.4i
Re: uphill judders
Post by henrym3 » Wed Dec 05, 2018 11:07 am
My money would be on the TC. Check the gb oil level and temperature.
IanP
Re: uphill judders
Post by IanP » Wed Dec 05, 2018 12:24 pm
TC lockup? As above easiset thing to do first is check the oil kevels
Re: uphill judders
Post by henrym3 » Wed Dec 05, 2018 12:33 pm
Make sure you or whoever is doing it use the correct procedures and the oil is at the right temperature
Re: uphill judders
Post by Alan Gunn » Wed Dec 05, 2018 12:46 pm
When i had a similar problem on my 320d i confirmed it by using some of this.
The box was very smooth after adding it so i went ahead and had the torque converter changed.
https://www.ebay.co.uk/itm/2-TWO-Tubes- ... 1438.l2649
or
https://www.ebay.co.uk/itm/LUCAS-STOP-S ... 1438.l2649
