Rear Disc Size
pcdee
Rear Disc Size
Post by pcdee » Sat Jan 26, 2019 8:02 am
I'm a bit confused over the rear disc size, I know there are two size 320 & 345.
I looked on Realoem see link below and it comes up Nation version china 320. I'm presuming that the disc size is 320 but would like a second opinion before I buy them from Euro as they got 50% at the moment.
http://www.realoem.com/bmw/enUS/showpar ... Id=34_1052
Re: Rear Disc Size
Post by X5Sport » Sat Jan 26, 2019 8:40 am
If you check that National option code for a ‘No’ it tells you the first part is the right one. The China only version is ‘ended’.
Selecting the part number itself ... 34216868940 gives the current version which seems to have superseded all others. I fitted Pagid on mine.
I believe the larger size is only used on the X5(M) and possibly the M50d. My 40d X6 only needs the 320mm dia disc.
pcdee
Re: Rear Disc Size
Post by pcdee » Sat Jan 26, 2019 8:50 am
Cheers mate.
£136.25 for rear disc and pads with sensor is a bargain and their Pagid
