Centre bore enlargement.
Posted: Fri Jan 17, 2020 12:58 pm
by sapphireblack
I have a fabulous set of style 435s in storage that only fit the X6 or X5M of course.
I'd like the rear pair of these to be able to fit an E70 should I pick one up at the right price. Does anyone know of a business who undertakes this work? I've tried the more obvious wheel refurb companies in these parts, Rimtec and Lepsons but without success.
It needs to be a business in the south really or logistics would doubtless make it prohibitively expensive.
Any help would be much appreciated.
Re: Centre bore enlargement.
Posted: Fri Jan 17, 2020 4:23 pm
by StuBeeDoo
I've had something similar done many, many years ago (Sunbeam Lotus wheels centre bores enlarged to fit on mk5 Cortina hubs). You want an engineering firm with a large lathe. I don't suppose a wheel refurb business would have the sort of tools required for actually milling the centre bore to the size you want.
Posted: Fri Jan 17, 2020 4:39 pm
by sapphireblack
I don't doubt you are correct, i approached the companies named to see if they knew of anyone capable. So far nil results
Posted: Fri Jan 17, 2020 5:11 pm
by weirdfish
As already said really, a decent engineering company will sort them out for you, usually find them tucked away on the industrial estates.
Posted: Fri Jan 17, 2020 7:10 pm
by StuBeeDoo
Do a google search on "small engineering companies in [enter your location here]"
Posted: Fri Jan 17, 2020 10:06 pm
by sid10
Any one ever changed the hubs to X6 ? surely this would be a better solution ? or wheel spacer adapters .
Posted: Sat Jan 18, 2020 9:56 am
by StuBeeDoo
sid10 wrote: Fri Jan 17, 2020 10:06 pmAny one ever changed the hubs to X6 ? surely this would be a better solution ?
That would be the ideal way to do it, but even using second-hand parts (assuming you can find them), isn't going to be cheap - and you wouldn't want to use second-hand bearings in any case.
sid10 wrote: Fri Jan 17, 2020 10:06 pm..............or wheel spacer adapters .
That will cause problems with wheel offset. They would need to be at least 10mm thick.
Posted: Sat Jan 18, 2020 5:23 pm
by sapphireblack
A hub change would be too costly and restrictive in its own way.
I'll endeavour to seek out a suitable machine shop to modify the wheels.
Posted: Tue Jan 21, 2020 10:15 am
by sapphireblack
Found a suitable company but they want a bare rim sent/delivered to assess before pricing. They won't even offer an indicative cost, so could be £20 cash or???
Another idea to abandon i think
Posted: Tue Jan 21, 2020 2:09 pm
by weirdfish
Until you take the job to show them you won't know.
In all fairness they're not going to price it until they've seen it, and you can also assess whether you want them to do the job for you at the same time.
Posted: Tue Jan 21, 2020 4:26 pm
by StuBeeDoo
weirdfish wrote: Tue Jan 21, 2020 2:09 pmUntil you take the job to show them you won't know.
Agreed!
Even if they want £50/rim it's cheaper than the alternatives............
If you're dead-set on having those particular rims on your car.
Posted: Tue Jan 21, 2020 4:45 pm
by weirdfish
Just a thought, how are you letting them know the bore size required, taking a rim that already fits for them to measure? or a hub?
Posted: Tue Jan 21, 2020 5:28 pm
by sapphireblack
It would have been a simple instruction, enlarge the 72.6 to 74.1.
But, I'm not willing to pay to have rubber removed just to have rims assessed. I'll either sell 'em or put them on a holiday E53..... should i ever get one
I've decided an E70 is more than i need for such use anyway.
