Brake pad sensor warning light
How-To articles ONLY go here.
weirdfish
Post by weirdfish » Sun May 31, 2020 10:25 am
I changed the rear pads yesterday but used the existing sensor, how do I clear the warning light on the dash
Vehicle is a 2003 E53 4.6
Re: Brake pad sensor warning light
Post by X5Sport » Sun May 31, 2020 10:57 am
Was it as a result of the light coming on that you changed the pads? If the sensor had warned you of pad wear then it has been ‘tripped’ and needs replacing as well. They can’t be reset.
weirdfish
Post by weirdfish » Sun May 31, 2020 1:54 pm
X5Sport wrote: Sun May 31, 2020 10:57 am Was it as a result of the light coming on that you changed the pads? If the sensor had warned you of pad wear then it has been ‘tripped’ and needs replacing as well. They can’t be reset.
Yes, the light came on the dash, I'll order a new one. :thumbsup:
