Anyone know of an automatic transmission specialist near Royston (Cambridge)?
The old range rover could do with a fluid swap..
Auto transmission service.
Re: Auto transmission service.
The only ZF service centre locally is in Bletchley, they wanted £1,000 to do a fluid change on my X6 transmission parts a year back. You could try asking A1 Premier Transmissions at Biggleswade if they do services? They certainly do rebuilds and oil changes after rebuild. I’m only about 15 miles from you.
All good. The local garage where it normally goes is going to give it an engine oil change and a transmission service. My neighbour is a mech there and is a land rover expert.
I did get a quote from Stevensons engineering of £357+vat to do a trans service but they are a 40 min drive away. The local is a 15min walk. Via the pub.
