2006 X3 3.0sd Air Con
Supercooper04
Post by Supercooper04 » Wed Aug 26, 2020 10:31 am
Hi,
Has anybody had any aircon problems with the 2006 X3 3.0sd, There doesnt seem to be any cold air coming out of my aircon system. The climate control display is working, the fuses are okay, the compressor is spinning and I think is okay, Ive checked the system for pressure and thats okay. When you turn the aircon on full the compressor doesnt seem kick in. Any ideas what I can check before it goes into a garage.
Thanks in advance
Sandy5454
Re: 2006 X3 3.0sd Air Con
Post by Sandy5454 » Wed Aug 26, 2020 12:13 pm
COuld just be the clutch has failed in the A/C unit. Needs to be checked by a competent A/C specialist. Most garages use a specialist to fix the A/C or just replace suspect parts with new. Th clutch can be replaced dont need a complete new unit. FInd a local specialist and go to them.
Post by Alan Gunn » Thu Aug 27, 2020 6:12 am
You say "Ive checked the system for pressure and thats okay" how did you do that.
